EM TuningAH Fabrications
Like Tree1Likes
  • 1 Post By Mike B
Thread: Pressure related coolant leak?
    Aug 2012
    Darlington
    171
    On my 1.9 130 I have a small coolant leak, which only needs topping up every 1000 miles or so. When I went to top it up a few days ago I noticed that with the filler cap off when topping up coolant started to run out of the bottom of the bottle quite quickly. As soon as the filler cap was replaced the leak almost stopped. I assume that without having an available air inlet the pressure of the system prevents the coolant from leaking as quickly as it does with the cap off?
    It appears to be leaking from what feels like the mounting point for a clip on the bottom of the header. Is there something there that is prone to leaking? Is it repairable or do I just get a new tank?
    How much coolant does the system take?
    Jul 2007
    766
    Check the tank for cracks.Yes the coolant will leak quicker when the cap is off
    Nov 2010
    206
    You sure you haven't spilled any around the filler cap?
    there is a hole to let spill ages drop down, found out to my own cost lol
    B6 A4 Avant 1.8T (190) S-Line
    Aug 2012
    Darlington
    171
    I haven't spilled any over the header. There is a chance that I spilled some over the threads if the tank has some form of internal channel that would drain it to the bottom?
    Jul 2007
    766
    Ther is a channel at the top of the threads that will catch any coolant if its not poured straight this then drains down the side of the tank.Use a funnel to avoid this
    Mollygoogle likes this.
    Aug 2012
    Darlington
    171
    Quote Originally Posted by Mike B View Post
    Great news, thank you. Makes perfect sense, but never had a car with a tank like that before.
  1. Coolant leak
    By petewon in forum General Technical / How To
    Last Post: 5th October 2006, 21:33
  2. A4 coolant leak
    By spud in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2006, 19:29
  3. Problems with S3, suspect coolant leak & Turbo dump/recirc Valve noise??
    By fasteddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 17:17
  4. coolant leak - need to id name of pipe
    By Fraser in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th March 2006, 01:03
  5. Possible coolant leak, any ideas?
    By jgrand in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2005, 11:46
