Wheel Bearing Removal Kits
Ian2012
NULL
Has anyone used these kits that pull the front bearing wheel out and push a new one in without taking the hub off the car? are they worth the money?
Ian
is this made for the Audi?
as the bearings (yes theres two) are pressed on to the hub and the whole lot bolts in then I can't see them working
ok i get it i thought there was just one big bearing a bit like old school audi 80/90 etc
year there is actually two bearings and one is a different size to the other and the shaft on the hub is stepped too
In my experience I would buy the hub complete with bearing and replace the lot as one
are they quite simple to do? I think mine may need doing but I'm not sure if it's not just noisy front tyres.
I took mine out when I replaced the upright - I would say its straight forward yes.
The guide I linked to above has it pretty much spot on.
its a little fiddly but can easily be done
I replaced the bearing and holder rather then the whole hub and bearing next time I will be replacing the whole hub though
Oh my god AlexGSi what a find thank you so much
10
15
11K
9
889
9
911
