Sky InsuranceEM Tuning
    Dec 2012
    21
    OBD Error Code "p1504" - Help..?
    Hi guys,
    Engine Management light came on a week or so ago, car drives absolutely spot on.
    Plugged it into my OBD cable, came up with error code "p1504", used the software to reset the codes. Driven it 300 faultless miles and it's come back on again!
    I googled the error code and it says something about an air leak - I'm not particularly mechanically minded, I've visually inspected the engine bay but can see anything obvious.
    What I was just wondering was, should I buy VAGCOM, would it give me a more specific error message?
    Any help would be greatly appreciated!
    Daniel
    Mar 2013
    Near Oxford
    356
    might help if you let us know what engine your car has.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,929
    this guy had the same fault code as you
    Hi There. Found the problem is is a split hose that comes of what looks like the throttle body and travels down under the engine.
    so id say smoke test to find the leak and take it from there
    Dec 2012
    21
    Quote Originally Posted by madmike01uk View Post
    Sorry, would help!It's an Audi A4 Avant 2.0l FSI
    this guy had the same fault code as you Hi There. Found the problem is is a split hose that comes of what looks like the throttle body and travels down under the engine. so id say smoke test to find the leak and take it from there
    Will have another look when I get time!Thank you
    Mar 2004
    Leicester UK
    133
    How do you do a smoke test?
  1. Help with error codes P1103, P0139 and P0411
    By royster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th September 2007, 22:12
  2. help, please decipher vagcom error codes!
    By skanky in forum VCDS (formerly VAG-COM) forum
    Last Post: 12th August 2006, 12:42
  3. VAG error code. Please help.
    By moschino in forum General Technical / How To
    Last Post: 11th April 2006, 20:34
