Badger5Sky Insurance
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By B5NUT
Thread: Help, 1.9 TDi not running
    Jan 2009
    150
    Can any one help, I changed the oil, filter and fuel filter. Ran the car up after to run the oil through the filter. Watched the GP then came back to the car and it wouldn't start. The battery died almost straight way and the fuel gauge was on zero?? There's no leaks at all but am missing 1/4 of a tank of fuel.
    Ive topped it up with fuel and have fuel up to the pump on the back of the engine, but nothing, the battery is on charge but it doesnt catch.
    Anyone with ideas? Need the car to take the kids to school in the morning.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,520
    last time i did a derv filter
    it took a good few mins to get started
    what do you mean battery on charge but doesnt catch ?
    Oct 2009
    Hull
    1,442
    I have heard of a few people having problems when they change the fuel filter and it takes ages to start
    I have never had a problem and have changed 7 or 8 of these and they just fire up and run with no trouble at all
    Jan 2009
    150
    The battery died after only about 10 secs of trying. The engine doesn't catch, it doesn't try to fire, nothing, just turns over.
    I have services this car every 6 months for 5 years. Changed the fuel filter every time. Never had a problem. Until now.
    2,175
    How old is the battery? I've once had a TDi take a good few cranks to get going again after a fuel filter change but that was on a 3.0TDi engine.
    Jan 2009
    150
    Found it. It was drawing air in from the new HALFORDS fuel filter. Filter isnt quite right, well thats going back.
    Moral of the story dont go to Halfords.
    2,175
    Halfords fuel filter... I would rather used an old pair of socks shoved in a baked bean can! Glad your sorted.
    SL11CKK likes this.
    May 2012
    RETFORD, NOTTS
    1,753
    i always use halfords filters.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    Glad you found the problem. When you get the proper filter, don't be alarmed if it still takes a while. I did mine and got more and more worried that I'd killed it, but suddenly it fired up and all was good. I hadn't primed the filter though, so it was probably my fault a bit too.
  1. Changed injectors 2.0 tdi ,but still not running right
    By james1985 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st April 2013, 20:55
  2. A3 tdi (110bhp) not running or even turning over
    By ciniq in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st June 2012, 08:48
  3. PLEASE HELP A3 TDI NOT STARTING
    By MAXDEX in forum General Chat
    Last Post: 8th November 2011, 07:36
  4. tdi not starting....... timing problems, any help out there?
    By shufti in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st December 2006, 18:47
  5. Help - Coil Pack changed but still not running right!?!?...
    By Jodi in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2006, 19:58
