EM TuningMonster Motorsport
Results 1 to 7 of 7
Thread: low coolant
    Jul 2005
    scotland
    420
    low coolant
    ive just noticed on my a4 that my coolant is slightly below minimum level in the tank.
    surely with modern systems the level shouldnt go down unless there is a problem, leak or something?
    should i put the car into the dealer for a check? would they charge me or would warranty cover it?
    imported_bubstar
    Re: low coolant
    It will 'use' coolant under normal use - Just top it up and keep an eye on it.
    BUT make sure you only use VAG coolant and don't top up with tap water.
    BUB [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Jul 2005
    scotland
    420
    Re: low coolant
    what ratio should it be kept at?
    imported_bubstar
    Re: low coolant
    You need 'G12 plus' Coolant
    2 parts coolant to 3 parts water gives -24'c Protection.
    But it's easier just to mix 50/50 - Gives -36'c Protection.
    MIx it with distilled water ONLY.
    Jul 2005
    scotland
    420
    Re: low coolant
    i take it volkwagen garages will sell this too?
    thanks for you help mate [img]/ubbthreads/images/graemlins/smile.gif[/img]
    imported_bubstar
    Re: low coolant
    Yep! and Skoda and Seat!!!
    They all use the same stuff.
    Jul 2005
    scotland
    420
    Re: low coolant
    brilliant, many thanks
