Sky InsuranceChris Nott
    Dec 2012
    Cumbria
    19
    MAF Sensor Quick Question
    Hi
    Replacing my MAF sensor on my 2001 1.8T and the new MAF has 5 pins in the connection however the plug on my loom only has 4 bronze connections, the car is running bad aswell, it will idle fine however under power the car bogs down and splutters.
    I have looked online but cant find a definitive answer, have I got the wrong MAF and should I try and get a 4 pin one?
    Joe
    Mar 2013
    Near Oxford
    352
    how does it run with the MAF disconnected?
    Dec 2012
    Cumbria
    19
    Quote Originally Posted by madmike01uk View Post
    Only driven half a mile or so with it disconnected but it was much better!
    pauldazzle's Avatar
    Cardiff
    549
    You have the wrong MAF. Get a genuine VAG or Bosch MAF as aftermarket MAF's rarely work properly. Buy cheap buy twice is the rule with all VAG engine sensors.
    The VAG 1.8t's will run on default settings if the MAF is unplugged, which is why it's a way of diagnosing a goosed MAF.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat pipe, 165bhp remap, EGR delete, Dunlop SP Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    Dec 2012
    Cumbria
    19
    Quote Originally Posted by pauldazzle View Post
    The Maf I got was a Bosch exchange unit (part no. 434440750), can anyone confirm this is the correct part no. for an a 2001 B6 1.8T? And as they have already sent my MAF away as I exchanged it straight away so I cant look at that for a part no. etc.
    The plug on the loom fit the connection on the sensor however the sensor had 5 pins.
  1. quick maf sensor question
    By kkk in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2013, 06:43
  2. Head Lamp Conversion, Exhaust and MAF Sensor Question!
    By a3t-ian in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2011, 21:57
  3. MAF sensor fitting question
    By MattW86 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th August 2009, 20:47
  4. MAf cleaning..quick question
    By Black_S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2009, 23:23
  5. n75 j valve and maf sensor question
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2006, 13:14
