EM TuningChris Nott
    Oily spark plugs
    Yet another problem, Just changed all 4 coil packs on my 1.8tq 190 and noticed that 2 of the spark plugs were oily! Does this mean the piston rings are shot?
    Mar 2013
    Near Oxford
    406
    where on the spark plug was oily? Could it be the rocker cover gasket leaking causing oil to pour down onto the plugs?
    The whole lot was oily on the one, even the coil pack was covered, I have discovered the spark plug on that cylinder wasnt in properly (loose and cross threaded) ((another brill audi servicing job)). But even so, the oil shouldn't get to it??
    Mar 2013
    Near Oxford
    406
    if it's on the top of the spark plug and the coil then I wouldn't have thought it would be blowing through the spark plug. I'd imagine it will be the rocker cover gasket gone and oil is passing through that way. If it was only the diode covered then I'd be worried.
    Jul 2007
    770
    The electrodes s/b brown maybe blackened if a lot of oil is getting in
  1. spark plugs
    By Danielson in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th September 2004, 17:02
  2. Spark Plugs
    By Bradley in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th September 2004, 19:23
  3. Misfire and Spark Plugs under warranty
    By DuncS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2004, 10:39
  4. spark plugs....???????.....
    By smudgy57 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2004, 17:33
  5. spark plugs
    By sahk in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th April 2004, 01:23
