Volks AutosAH Fabrications
Results 1 to 8 of 8
    Jul 2013
    32
    problem after remap 2.5tdi 163bhp
    Had my a4 remapped made some difference but they told me the turbo was kicking in late he said was a common fault so I changed the turbos wastegate actuator like they said but i got my mechanic to change it got the the car back the remap was gone no power took it to were it was mapped thinking did my mechanic wipe the remap but found out it cant be.
    The car runs smooth been service timing belt changed before the remap, So got the egr blanked to see if that helped but no so I am booked in on monday to get the old one fitted hoping that will put it back to the power the remap had not had much luck with my first audi love the car but has cost me a fortune since the start of july, my tddi mondeo tuned never give us a problem it had 160k on the clock double the miles of the a4
    Any one had this problem before that could help me?
    My cars a 2003 audi a4 2.5 v6 tdi (fwd) 163bhp 83k on the clock
    Jul 2007
    London
    3,252
    More likely your mechanic has inversed the pipes/connectors of the ER valve to the boost valve... seen it many times !
    FOR SALE:
    Jul 2013
    32
    Thanks was hoping you would reply been reading alot of you treads, you know theses 2.5tdi inside out will tell them to check it when its left in and again thanks for your help
    Jul 2013
    32
    Just a update adamss24 the pipes you suggested were fitted right
    The fellow that fitted the actulator just stuck it on he never set it so the fellows that remapped tryed to set it right so now the power from the remap isnt there so I dont know what to do now not happy
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,159
    May be worth getting some logs done using VCDS and popping them up here - it will show us the values recorded so we have abit more of an idea.
    The actuator may not be adjusted correctly though?
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Jul 2013
    32
    Whats vcds if you dont mind me asking?
    Is there a way of telling or finding out how to set it right am new to audi
    Jul 2007
    London
    3,252
    You need VCDS also known as Vag-com- it's a VAG diagnostic system. You need to do logs in order to set the actuator properly !
    FOR SALE:
    Jul 2013
    32
    It was put on adianostic when I took it back to were it was , mapped no codes came up am thinking of getting the old actuator fitted it seems to have some yellow paint just above were we think it was set , or the new one was damaged in the post coming over from england
  1. Any problems after remap on a S-Tronic S3.....?
    By Amos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2011, 15:22
  2. Running Lean and bad Idle problems after remap
    By Ryanmt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th October 2010, 11:26
  3. Turbo problems after remap
    By bigjim in forum Tuning
    Last Post: 30th January 2008, 19:34
  4. Problem after remap :(
    By klepto in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2007, 09:25
  5. Anyone had any problems after remap?
    By 18ME in forum Tuning
    Last Post: 31st July 2003, 08:31
