Volks AutosSky Insurance
Results 1 to 13 of 13
    jamesey's Avatar
    Sep 2013
    derbyshire
    90
    avant a4 rear light loose how do they come out /tighten up?
    hi ive noticed damp in my rear light and just seen that its loose now ive got the bose system behind the light so it must pop out from the outside?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,695
    Open the boot, and halfway up the light cluster on the inside is a 10p sized gromet in the plastic which will pop out. Behind here is a screw (Torx I think but I can't remember) - remove this, DO NOT DROP IT. The whole light unit will then remove, from memory it pulls out from the rear and hinges out from the side. You can then unclip the loom, and all the bulbs are in a removable PCB.
    Don't drop the screw.
    andy.l's Avatar
    Aug 2013
    Bristol
    130
    It is a torx bit (or should be) my right one was a 10mm hex bolt now rectified
    jamesey's Avatar
    Sep 2013
    derbyshire
    90
    cheers ive lossened the screww and taken it out , the outer pins go into the rubber gromets which hold the outer light in but there not for some reason causing damp in my lamp
    ive tightened the torx bolt up very tight but the lamp is still loose the other side is tight ,perfect , any clues?
    May 2013
    redditch b98
    209
    Add bradh on Facebook
    Not much of an input but mines the same one right light one loose light so if any one has a fix I would be very interested
    Mar 2008
    Dorset
    13,695
    Are you saying the small ball on the light lens doesn't sit tightly in the rubber grommet of the bodywork?
    Have you tried wrapping tape around it to make it fit snugger or anything?
    Jul 2007
    765
    I had damp or condensation caused by damage in the sealbeneath the outer skin.Cleaned the dirt as much as possible and spent some time on a sunny day with a hair dryer trying to dry it out .Much better now so sealed gap with some clear silicone.Fiddly job and ideally best to let it dry out naturally in the sun .Loose fit might be due to someone using the wrong screw if they have lost the original easy done .If the unit can be pushed tight against the body then the screw isn't tightening fullyIt seems the seal inside the gate can be easily left inside not outside the bodywork which lets water back in over the cluster.Not the greatest design for DIYers
    jamesey's Avatar
    Sep 2013
    derbyshire
    90
    ill check the screw on the other side and see if its the same or ill try the tape method lol
    andy.l's Avatar
    Aug 2013
    Bristol
    130
    My NS rear lamp is a bit loose too even when the bolt is tight and the right isnt,im thinking maybe its an aftermarket part ??
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    437
    All please note that its common for the tab/bracket that the bolt goes through snapping, the light is still held in by the boot lid when shut but will move around in its recess. If snapped in situ then it looks like its bolted up and you can tighten all you want but the light fitting will still be loose.
    Audi S4 quattro in Dolphin Grey Metallic, Silver leather, carbon inlays, RNS-E, 6 speed manual, electrically adjustable & heated seats, xenon headlights with power wash, cruise control, storage pack, 18" OEM RS4 wheels, RS4 ARB, LED lighting upgrade, FASH plus every bill since new.
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    437
    P.s mine is currently broken near side and it has been for 6 months, will swap out for a replacement when I get round to it. Light fitting can't come out while boot is closed.
    jamesey's Avatar
    Sep 2013
    derbyshire
    90
    sorted it,,,looked on the other side and it was a different bolt , long story short the bolt on the light sticking out was too long. nice fit now.
    Jul 2007
    765
    Quote Originally Posted by jamesey View Post
    Thought so must be common.Why didn't they design it to stop the blot dropping out/
  1. B5 avant Smoked rear lights
    By disley in forum For Sale/Wanted - Audi Parts
    Last Post: 13th July 2012, 17:12
  2. FOR SALE : A4 Avant Smoked Rear Light Set NEW & UNUSED
    By Keyser Soze in forum For Sale/Wanted - Audi Parts
    Last Post: 4th June 2011, 20:33
  3. Do they come out the factory like this?
    By dantdi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th August 2010, 00:33
  4. S3 8P2 mirror cap removal - help, how do they come off!!
    By RicoS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th June 2010, 21:46
  5. how do speakers come out on parcel shelf
    By turboaudi in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2007, 16:15
