    Sep 2013
    Hucknall, nottingham
    Exclamation Abs and traction control lights on dash after installation of new shape brake switch
    Good morning,
    i recently had rac out to check diagnostics after my brake lights were staying on all the time. Only fault code was brake light switch. after fitting two brake light switches, of which were the old type from Eurocar parts. They did not work. Rang audi to get some advice. I opted to buy a new switch from them in case I had two bad ones from euro. The audi one worked straight away even tho it was a new model. Now the brake lights are working fine with the new switch, however after a min driving get abs and traction dash lights come up, they reset if I turn engine off and on. My question is do I need to reset the original fault code. or am I just unlucky and had a abs sensor or something go directly after rectifying the original fault.
    car- audi a4 cab b6 3.0 petrol.
    thanks guys
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,510
    get it scanned for codes again
  1. ABS and Traction control light just came on
    By Jason-Con in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th August 2010, 07:35
  2. ABS and Tracion control light on all the time.
    By myke in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2010, 02:24
  3. engine management light and traction control light always on
    By martin9k in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2010, 13:31
  4. ABS and traction control light
    By joshwalters123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2009, 18:47
  5. Engine management and traction control light
    By JUX in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th October 2009, 12:11
