Sky InsuranceChris Nott
Results 1 to 10 of 10
    davidfox280585's Avatar
    Aug 2009
    108
    a4 2.5tdi very bad starting missfire/stutter 1800rpm?
    my a4 has never started great but always fired on 5th turn, now its spinning over 30 seconds before it fires up with a cough and loads of smoke
    checked intank pump by powereing fuse 28------- all ok
    replaced cooland temp----------------all ok
    checked power to glows------------all ok
    new diesel filter-------------------------all ok
    checked cams for wear all seem ok
    code read----------------------------no codes except egr recirc due to blanking plate
    its a 2.5tdi 163 cab manual
    no im at wittsend with the thing, the car always has had a bad vibration under acceleration like 2 cv joints are gone,also driving steady about 1500-1900rpm it stutters and holds back and when you accelerate it on boost its perfect
    could it be a dualmass?
    pump timing? can i adjust this myself manually or is it vcds only
    pump issue?
    anyone encountered similar
    Jul 2007
    London
    3,074
    Where abouts are you mate ? Fancy a drive down to london ? I could have a look at it for you...
    FOR SALE:
    Aug 2009
    108
    in doncaster so a bit far i understand your the man for the v6s i really cannot understand what is causing it
    Jul 2007
    London
    3,074
    Pump timing might be out, get someone with fully registered VCDS to check it for you and adjust the timing towards the top line...
    Chances are the timing it's so advanced it might not even show on the graph at all !
    FOR SALE:
    Jul 2007
    London
    3,074
    Quote Originally Posted by davidfox280585 View Post
    I had folk coming from Preston, Leeds and even Wales for me to work on their cars...
    FOR SALE:
    Sep 2012
    LEEDS
    116
    I have travelled down from leeds this saturday and can thoroughly recommend him he's fair and thorough.
    I have used him a few times and also asked for his avice before buying a 2.5 tdi quattro.
    This guy knows them inside out .
    Also great wealth of knowledge if you need to pick his brains too
    genuine parts =genuine service
    Treat it right it'll keep you on the road .
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,197
    I Went from Hull. wouldn't hesitate again and wont when my cam belt comes up
    May 2012
    RETFORD, NOTTS
    1,706
    If you cant make the trip and adams is happy to advise you over the phone id be happy to plug you in. im in doncaster quite a bit with work but dont have too much experience with timing issues.
    However, I travel nationwide to help others and get help, im due in devon on 15th september to meet up and get some advice from somebody, going by adams feedback it would be well worth you taking a day out :D
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Dec 2006
    barnsley
    924
    i live in barnsley and have vcds if its of any use
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Aug 2009
    108
    Quote Originally Posted by adamss24 View Post
    will bear it in mind but already have it booked in somewhere,
    the misfire/stutter has gone just poor starting now
  1. Audi A6 Estate 2.5TDI 2000reg intermittent start problems
    By Khi in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th July 2010, 13:31
  2. LOL, Warning very bad language.
    By S3-Oski in forum You Tube Links
    Last Post: 15th January 2010, 00:04
  3. HELP - Car in very bad way....
    By tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th July 2009, 18:32
  4. bad start up on 2001 1.8t
    By wackojacko in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2007, 23:15
  5. Bad Starting!
    By imported_davea in forum General Technical / How To
    Last Post: 14th September 2004, 11:02
