EM TuningChris Nott
    Mar 2008
    1,053
    fx coilovers ???????????
    got the rears fitted the other day and are awesome but i got em sat to low so i tryied to adjust them and the problem im having is when you try adjust the drivers rear side the hole thing turns so it wont adjust but take the load of the spring and i can turn it ..but the passenger side rear will adjust ok without taking the load of the spring ... any ideas anyone ?????????
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    I had the same on mine but im ok with drop.
    I was gona take it to local steel fabricators,for a couple of spot welds.
    If you have a pal,u could jack up up and get him lever some weight on wheel so it can free up more and make your adjustments.
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
  1. KW Coilovers
    By XXX_18T in forum Handling
    Last Post: 11th November 2003, 06:07
  2. Replies: 5
    Last Post: 30th October 2003, 03:20
  3. H&R Coilovers... Please help for the S3
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 06:28
  4. Coilovers vs dampers & springds
    By dbm in forum Handling
    Last Post: 4th September 2003, 07:36
  5. Quick question about Audi a4 coilover kit
    By anwar in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2003, 22:13
