AH FabricationsEM Tuning
    Aug 2013
    north east but relocating to Cornwall nxt year
    help needed with ns folding mirror
    Hi guys new on the forum but onto my 3rd cabrio. Bought a 52 plate a4 3.0 sport recently, love everything about it but the only problem I have is that the ns mirror doesnt dip when reverse is selected and also wont fold in as the drivers one does. Dont know whether its supposed to tint like the drivers one and rear view mirror do. Any help wouod be greatly appreciated
    Mar 2013
    Southampton
    128
    Hi,
    The N/S mirror will only dip if the car has the memory option, and the mirror switch needs to be switched to the N/S mirror for it to dip when you put it in reverse.
    Is the glass the same as drivers side? ie has it got a line all the way round the glass about 5-6mm all around it? if so it should dim.
    Aug 2013
    Cheers andy il check in the morning. Should the mirror fold in as the drivers side does from the switch. Wondered wether it could be a fuse or relay blown thats stopping it
    Mar 2013
    Southampton
    128
    If one mirror folds then so should the other so I think you can eliminate a relay or fuse, its more likely to be a broken cable in the hinge area of the door or the mirror.
  1. Can someone with power folding mirrors help please......
    By chasdrury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th June 2012, 18:31
  2. Help needed with car accident damage.....
    By imported_spuddie007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th November 2005, 13:01
  3. Urgent help needed with value of sat nav plus
    By imported_Tariq in forum In-Car Entertainment
    Last Post: 23rd November 2004, 17:07
  4. Help needed with S3
    By jeffreyyeung in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2004, 13:17
  5. help needed with a mod!!
    By imported_Tariq in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2004, 17:48
