    Avo
    Avo's Avatar
    Ex-pat
    Jan 2011
    Belfast NI
    35
    Temp gauge or Temp sensor faulty ?
    Guys looking a wee bit of help in narrowing down a fault/problem.
    i have a 2004 A4 Avant (B6) 1.8T (163), I have a temperamental fault in that the temp gauge varies between showing normal temps when running to way over past the max, when the car is cold is still sometimes shows 90degs on the gauge.
    Temps according to Diagnostics are normal.
    Anyone else had this problem or similar that can shed some light ?
    Cheers guys.
    May 2012
    RETFORD, NOTTS
    1,704
    Temp sender, bad earth, or bad cluster.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    pauldazzle's Avatar
    Cardiff
    549
    Change the CTS ( genuine VAG only).
    The CTS 2 seperate outputs, 1 to the gauge, 1 to the ECU. It's common for just 1 output to fail, so I think the gauge output is goosed on your CTS, hence the temp reading normal on diagnostics..
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat pipe, 165bhp remap, EGR delete, Dunlop SP Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    Avo
    Avo's Avatar
    Ex-pat
    Jan 2011
    Belfast NI
    35
    Cheers guys for that
  1. Possibly Faulty Temp Gauge ?????
    By amicallef1991 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2013, 19:55
  2. Diverter Valve Location / Temp Gauge Sensor Location and MAF (2.0TFSi Quattro)
    By Scott.T in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th October 2012, 21:34
  3. Temp Gauge / Which Sensor ?
    By Andy H1962 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2011, 19:17
  4. possible faulty temp gauge a6 2.8 30 valve
    By yendall24 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th July 2009, 12:18
  5. S3 temp gauge / sensor problem.
    By benjy_a in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2008, 22:54
