Boot eye level brake light
I can only speak for a saloon, but looks relatively easy in my opinion
yes i had mine out last night
take warning triangle out 2 screws behind it
1 screw under the small black plastic part you hold to close boot
pull the big carpet trim off
then you will see the 8 screws to get the light out
also are you sure its the light ? the break switch may be ******** yes it can just make the center light not work
also mine was playing up and i removed unplugged and cleaned the terminal up good as new now
