JMB RetrofitsSky Insurance
Results 1 to 28 of 28
Like Tree3Likes
  • 1 Post By gen.heinz guderian
  • 1 Post By IceHanger
  • 1 Post By dsmclark40v
Thread: Clutch Life S4
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Add GeoffDunk on Facebook
    Question Clutch Life S4
    Hi all,
    Just wanted some advice on clutch life info for a 2003 S4, it also has 111k on the clock?
    How long shoudld they last ( driving style taken into consideration) and what should be replaced when changing the clutch if a change is required? My initial list would inlcude the rear engine oil seal as mine leaks but should I include other items while in there?
    Any other ideas or advice would be greatly appreciated.
    regards,
    Geoff
    Audi S4 quattro in Dolphin Grey Metallic, Silver leather, carbon inlays, RNS-E, 6 speed manual, electrically adjustable & heated seats, xenon headlights with power wash, cruise control, storage pack, 18" OEM RS4 wheels, RS4 ARB, LED lighting upgrade, FASH plus every bill since new.
    Jun 2011
    213
    rear seal as you said and once they start you can end up with quite a leak there, i had mine done and most people replace the fly wheel as well. S4's often seem to have it all done around 80-120k, some less if people have a habit of launching them from standstill which they don't put up with for very long.
    Dec 2006
    barnsley
    1,016
    if you need to put the car into the service position to do any of the work
    auxillary belt
    front engine mount ...
    may also want to check main engine mounts while its all it ... if you have any fluid leaking from engine mounts then change them
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Thanks for the details guys, I can start putting a list together (my 100K list).
    I had seen someone list jobs to undertake and parts to inspect/replace and or repair at 100K but couldn't find it.
    I had asked this question a couple of weeks ago regarding jobs for 100K MILE s4 but nobody had much to add. see here
    Dec 2006
    barnsley
    1,016
    snub mount is the front engine mounting
    it basically tries to counteract the lateral forces when the car is revved ... and so the car doesnt jump from side to side like a lot of old american v8,s when revved
    its fitted in two parts one fits with 3 allen key bots to the engine itself the other part is the reciever which at the back of the radiator mountings on the front of the car .... you need the car in the service position to replace it
    whilst its in the service position its easier to replace the auxillary belt and tensioner
    and if you have cam cover leaks like many s4,s its easier to replace the rubber gaskets and seals while its like this as theres very little room to work
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Quote Originally Posted by dualmono21 View Post
    Thanks for that info, I have replaced the rocker cover gaskets, did that as soon as I got the car and I keep an eye on them for obvious reasons.
    Also, can you explain "the service position", what do you actually mean?
    Jun 2011
    Great Melton Norfolk
    1,349
    Service position is moving bumper out to access belts etc,the bumper loosens and can move forward 8" to gain access.
    dualmono21 likes this.
    Dec 2006
    barnsley
    1,016
    to properly service the s4 and some of the a4,s audi designed to car so as you can remove the front grille and the headlights
    and put the car into whats known as the service position
    the bolts are removed from the front panel and two extra ones are put in
    from there the entire front assembly can be pulled forward around 6-8" to assist in any servicing requirements
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    I geussed that was what it was. This is common on most VAG vehicles, my Golfs and Passats were the same.
    Thanks for the clarification guys.
    IceHanger's Avatar
    Dec 2011
    West Mids/North Worcs
    291
    Quote Originally Posted by GeoffDunk View Post
    Service position on mine when I did the Aux belt..ie a PITA!
    rjm180 likes this.
    IceHanger
    2011 S3 8P 5DR Black edition,
    2013 TT TDi BE with lots of toys
    Previous Vehicles:
    Audi S4 B6 4DR Big fuel bill edition
    Audi TT TDi S-line Quattro
    Skoda Octavia 4x4 Turbo,
    Skoda Octavia VRS Estate,
    Vauxhall VX220 Turbo,
    MGF VVC,
    Vauxhall Astra GSi,
    Alfa 33 Cloverleaf,
    Tons of Minis
    dsmclark40v's Avatar
    Sep 2006
    Hampshire
    715
    You should also change your clutch slave cylinder while you have the box out. Are you changing the flywheel as well?
    Sam,
    Gone
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Will do.
    Flywheel is on the list along with:
    Clutch, pressure and friction
    Thrust bearing
    Flywheel
    Rear crank seal
    Cam chain tensioners
    engine nounts
    Anyone have any other ideas or additions?
    Dec 2006
    barnsley
    1,016
    why are you changing the cam chain tensioners geoff ??
    are they especially noisey ???
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Not excessively noisy yet but they are not as quiet as I'd like. While we have access I will change them.
    On cold start up they rattle for a second or two.
    Dec 2006
    barnsley
    1,016
    thats normal .. if the rattle goes on any longer than a couple of seconds then you have trouble
    very shortly there should be other options available that will mean you will no longer need to resort to having tensioners replaced
    biyitch's Avatar
    Chocolate? It's doo-doo, baby!
    Southampton
    316
    ...very shortly there should be other options available that will mean you will no longer need to resort to having tensioners replaced
    Please expand.
    Audi S4 Avant (B6, 2004) in Goodwood Green.
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Would like to know a bit more!
    Mar 2009
    470
    Now you've started something, come on we need to know! Please!
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    Sep 2006
    Hampshire
    715
    You won't have access I am afraid with the gearbox off. Needs the whole engine out to change those. My old car even after having every tensioner changed still rattled. In the end changing to 5w40 oil changed every 4-5k stopped it rattling
    vivalacoulter likes this.
    Sam,
    Gone
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Quote Originally Posted by dsmclark40v View Post
    Cheers for that, good info and top tip.
    Added a reputation pint for that one!!!
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Oops, I meant point, but pint will do lol.
    Dec 2006
    barnsley
    1,016
    there is a product which is in pre production at the moment
    when finished it should allow you to connect a second oil line up to the 0il filter housing
    this second line is attached to a pressurised oil container and when the engine is switched on the container actuates and forces extra oil into the oil filter housing and pressurises the tensioners in the engine
    this should hopefully cure the start up rattle
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    With the rear seal leeking I change the oil regular by default.
    What 5w40 oil are you using, I am currently using 5w30 as specified by Audi?
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Who's developing this?
    Dec 2006
    barnsley
    1,016
    the company producing this is in the states
    when the product is finished i will be the installing the system on my car to ensure it works o.k
    if everything is o.k from there they will be making a limited production run of the parts
    all in all with parts the system should be around £500 plus fitting , but apparently is so easy to install that most people simply do it themselves
    if people are interested please let me know and i can feed this back to the company
    Nov 2012
    Warwick
    41
    This already exists, called an Accusump.
    Will deliver pressurised oil on start up and if ever the oil pressure drops.
    Tom.
  28. #27
    Sep 2006
    Hampshire
    715
    I used Fuchs Titan Race Pro Sadly no longer own the car. What make oil do you currently use? You could always try the Fuchs in 5w30 first to see if it clears up the rattle.
    Sam,
    Gone
  29. #28
    Dec 2006
    barnsley
    1,016
    accusump can be used yes a long with lots of differant brand systems which are designed to stop oil starvation when cornering hard
    however nobody at present makes an adaptor which is specific to the bhf and bbk engines
    so it is difficult to plumb it in and get it work correctly
    i still use fuch titan 5w30 as it seems to help with the start up
  1. S3 Clutch Life
    By Hellz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2011, 00:53
  2. Clutch Life
    By cheekeemonkey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th October 2009, 21:45
  3. clutch life question ?
    By stevess3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th August 2008, 19:13
  4. S3 Clutch Life
    By SimonP in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2007, 15:21
  5. TDi Clutch life
    By samuelt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th April 2007, 18:38
