Results 1 to 7 of 7
    Oct 2010
    341
    Aerial amplifier pc5-52
    I have an aerial amplifier pc5-52. It also has a blue wire coming from it. Is this connected to remote or the ignition wire I will wire in?
    Apr 2007
    Wirral
    191
    You can connect to the remote lead from your head unit if your not using it to run an amp otherwise connect it to the power antenna cable from your head unit, usually a blue and white striped wire.
    Oct 2010
    341
    The remote will power sub as well. Is it too much to power both?
    Apr 2007
    Wirral
    191
    Wire it to the power antenna wire then.
    Oct 2010
    341
    The power antenna is also the remote it's the same wire.
    Apr 2007
    Wirral
    191
    Most head units have separate wires for this. If you only have the one just wire the amp and antenna and it should be ok to power up both.
    Oct 2010
    341
    Connected to ignition live in the end.
  1. audi a4 aerial signal amplifier 2002
    By markk320 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th May 2013, 22:27
  2. A4 B7 saloon aerial amplifier, price please.
    By ukdan in forum Parts Requests
    Last Post: 2nd January 2013, 13:52
  3. How easy is it to replace the aerial on my S3?
    By bigshout in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2005, 17:50
  4. Radio Antennae Aerial
    By hfu in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2004, 09:25
  5. Is it an amplifier????
    By RSAudi in forum In-Car Entertainment
    Last Post: 5th August 2003, 16:59
