EM TuningBadger5
Results 1 to 8 of 8
    andy.l's Avatar
    Aug 2013
    Bristol
    146
    Please help with rear bumper/exhaust set up
    Hi everyone,I've just done a massive search looking for the correct way to go about fitting these twin exit exhausts but I'm just getting lost. I quite like the look of them rather than the hidden type on the rear of my Avant. Can someone please add some direct links to the stuff I will need to change over please.
    Apologies for the picture usage if this is someones car
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    You'll need a standard or GmbH rear to fit your car (saloon or avant?) See the Bumper Options sticky for the styles of bumper, and the Part Numbers sticky for the part numbers.
    Then, depending whether your car is a quattro or not, you'll either need new tips to weld on the existing back boxes, or you'll need a replacement exhaust system for something with a twin exit set up (1.8T, V6 etc).
    It's hard to be any more specific without knowing about your car.
    andy.l's Avatar
    Aug 2013
    Bristol
    146
    Sorry,my car is a 1.9 TDi Avant with the standard hidden rear tailpipe
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    606
    Mines was the same as yours,single hidden tailpipe. Went to local powerflow (loads around) and said what i wanted.
    Since then though ive gone rs4 bumper
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. KRAPtuning custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    andy.l's Avatar
    Aug 2013
    Bristol
    146
    Thanks for the reply, your car looks great with the Powerflow
    Jun 2013
    54
    Hi i have just done this to my 1.9 tdi 2 wheel drive. I used a standard dual exhaust from a 1.8 t petrol saloon, which fitted straight on. All i needed different was the extra right hand rear exhaust hanger which bolted straight on and bought from audi at aprox 15 quid.
    I have the sport model with no exhaust cut outs, so i just did a bit of measuring and cut the holes my self then sprayed the whole middle section black. Could do with the dual hole rear valance tbh but they are hard to come by.
    So apart from the cutting of the holes the rest was very straight forward and just bolt on stuff. Also loads and loads cheaper than getting an exhaust made.
    Before:
    After : 20130801_172937.jpg 20130801_172538.jpg hope this helps .
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    398
    I have 1.9tdi FWD Se sport.
    has no cut outs.
    i fitted a votex rear so am I right in saying I just have to get a 1.8t middle section back exhaust and a O/S hanger and it will bolt straight on?
    sorry to hijack but on the same boat
    03 Mig blue 1.9tdi 130 saloon:- GMBH front, dark tints all round, fk coilovers,
    BMW TIGERCLAWS 19" 9j front + 10j rear, debadged rear. HIDs 6k, egr delete
    cominig soon:- votex rear,front end respray, parrot kit, remap, full paint correction
    Jun 2013
    54
    Quote Originally Posted by mattyb6 View Post
    has no cut outs.
    yeah that will work , it's all the same set up underneath , as long as its the same wheel drive ,as in front wheel drive or four
  1. Help with rear brake light problem please?
    By snorkelboy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th September 2012, 16:32
  2. A3 with S3 rear bumper? Exhaust discussion here
    By Imteyaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2010, 11:50
  3. HELP WITH FRONT BUMPER PLEASE!!
    By smythey1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2010, 20:46
  4. help with rear main oil seal please
    By PARKER in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th July 2009, 13:00
  5. A3 rear bumper exhaust cut out
    By ricklennard in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2004, 08:23
