Sky InsuranceVolks Autos
    Aug 2013
    Question Audi A4 cab probs
    I was only thinking 2 weeks ago how fabulous my 2002 gold A4 is.
    The roof goes up and down like a dream! Now it,s a nightmare.
    I had a problem a few years ago and having manually reset it It once again worked lovely.
    I decided to try to re glue the rear window last week and on trying to re close the top it refused.
    Reset it manually but no joy. Then took a look at connectors and had a general feel around for loose cables but nothing.
    Finally bit the bullet and dropped it into AUDI. Initial cost £57.
    Advice ..... Top lock mechanism requires physical checking £114 an hour ... and possible replacement at £800 !!! EIGHT HUNDRED POUNDS !!!!!
    I will follow the advice from the thread but my problem is the front clamps are not releasing (top lock mechanism). With a little help ... sometimes the roof will go up ..... or down ...... but doesn't do the whole thing ...... frustrating.
    I did notice over the last several months that the warning roof light was flashing too many times so suspect the boot cover is not fixing fully in the upward position.
    Will attempt to follow the advice given and get back on my progress
    Clive
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,474
    id like to see the codes audi got from the scan
    it will be a sensor at fault audi only do the scan look at code and fit what ever it says
    it really needs a good amount of time checking all sensors with vcds
    Aug 2013
    Talking CODE FAULTS
    Good Morning BEZ101,
    Audi have sent this list to me.
    Thanks for the help in anticipation ....
    List of fault codes as requested:-
    00532 002 Power supply lower limit not achieved Sporadic
    01995 008 Switch for convertible top lock, close - F295 Implausible signal
    01996 008 Switch for convertible top lock, open - F294 Implausible signal
    02000 008 Switch setting Implausible signal
    02024 005 Adapt No or incorrect basic setting / adaption
    Quote Originally Posted by bikingback View Post
    Clive
    Aug 2013
    Audi A4 roof fix
    I cant believe it.
    Took out my tools outside to spend some time on working on the Audi. I wanted to check connectors on the top lock and the boot latch.
    Decided to see if it would work!!! It did !!!
    My brother in law, yesterday, took the switch (by the handbrake) out and disconnected it, sprayed some electrical cleaner into it.
    Now it did not work yesterday but seemingly, now it has dried, the roof is working. One happy chappy! Just hope it is not a fluke.
    SO THE BEST ADVICE BEFORE TAKING IT TO AUDI IS ----- TRY DISCONNECTING AND CLEANING THE SWITCH.
    Clive
    Feb 2011
    Leicester, United Kingdom, United Kingdom
    356
    I cant believe it.
    Clive
    Hello Clive,
    I'm my experience the top lock motors get seized up.. You can remove them and lubricate...
  1. Audi a4 cab multitronic buying advise
    By little ted in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd March 2009, 15:15
  2. Audi (B6) cab to RS4 (B7) cab conversion
    By Dchaos in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd January 2009, 11:00
  3. Audi A1 cab + Audi RS1
    By WHITEY_1 in forum General Chat
    Last Post: 5th February 2008, 18:23
  4. k Reg Audi 80 housing prob
    By Broken Byzan in forum Classic Audi Forum
    Last Post: 8th October 2006, 19:48
  5. HELP Audi 80 sport prob
    By lenin in forum General Technical / How To
    Last Post: 21st April 2004, 09:30
