Monster MotorsportVolks Autos
    imported_Smudge973
    External Temp thermostat
    Since Tuesday the external temperature guage has been reading between 9.0 degrees C and 12.0 degrees C - It definatly not been that warm - It was very frosty this morning and it was reading 12.0 degrees - Anyone had this before ? Where is the sensor located ?
    Cheers chaps.
    Nov 2005
    UK
    44
    Re: External Temp thermostat
    Its 10c here at the mo.
    imported_Smudge973
    I would not see it as a problem, but no matter when I check it's always the same - Had to defrost the car this morning - it was very cold. Just had the car serviced on Monday - Only happened since then.
    imported_G4JSG
    It's behind the front number plate, open the hood and you should see it.
    Temps seem to be same as over here.
    John
    imported_Smudge973
    Ok - I'll see how it goes for the next few days.
