Results 1 to 13 of 13
    Jun 2013
    west mids
    17
    OH MY GOD !!!!!!!!!!!!!!!!!!!
    just snapped the f...n bonnet catch off does any body know how to get the bonnet up without doing any damage cheers in advance ITS A S4 B6 SALOON
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    PITA
    rip the grill out
    i tried for days and ended up smashing the grill out
    Jun 2013
    west mids
    17
    NOT GOOD THEN ???? PROPER PISSED OFF NOW !!
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,333
    Could drive it to a dealer... not sure wether they'd be sympathetic or charge there usual silly price for a fix though.
    Mar 2009
    470
    Think Bez is right, I had a quick search on google and going through the grill and then having to buy a new one or used on eBay may be cheaper than going to a garage or to Audi. Might be worth a phone call to them first though. Good luck.
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    Andie0's Avatar
    Aug 2012
    487
    You might be able to get a hook a pry at the clips behind grille through holes they are located at top! So as you pull try and pop the catches
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    The grille is the best way I think, shame you have an S4 though!
    Jun 2006
    UK
    143
    Can you access the bonnet release cable from where the handle snapped? If you can you could use pliers to pull it open.
    Mar 2013
    Near Oxford
    403
    what's actually broke? The handle inside the car? If so as said above just get some pliers on the cable and pop it open.
    Dec 2006
    barnsley
    1,016
    if you can do it any other apart from breaking the grille do so
    the grille is stupidly expensive compared to an a4 one
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,564
    Try removing the handle mech from inside the car first and see if it is broken that end.......if broken then find end of cable and use pliers on it..........but if not broken then the grill method.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Jul 2007
    London
    3,234
    As above, however the bonnet cable goes trough the wing so if you remove the inner wheel arch cover you should be able to see the cable. I would however buy a new plastic handle and use that to open the bonnet, the bit at the handle end has a habit of snapping off if you use pliers ! Ask me how i know...
    FOR SALE:
    May 2013
    25
    Relatively easy if long winded. The front grill will unclip - there are 4 clips IIRC on the top edge of the grill which you can get to with a flat blade inserted at the top of the grill. You can tell where they are by gently pulling the grill until it releases - BE GENTLE! Once the grill is off you can see 3 nuts holding the bonnet catch to the bonnet. Use a ratchet spanner - 2 are easy enough the third is a pain as you can only turn it a small amount at a time, turn the spanner over and turn it a little more and so on. Took me 30 minutes just to get this 1 nut off. Once off the bonnet is free and can be opened.
    As before if you have snapped the handle you should still be able to pull the cable from the inside but if not try the above.
  1. remaped my PD130 ... oh my god :)
    By smanning in forum Diesel forum
    Last Post: 7th November 2003, 15:42
  2. OH MY GOD LOOK AT THIS!!!!!!!!!!!!!
    By tvr1 in forum General Chat
    Last Post: 13th August 2003, 17:41
  3. Oh god that was one helluva weekend
    By gtdog in forum General Chat
    Last Post: 4th June 2003, 17:53
  4. Oh...my...god....look at this S3
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2003, 18:03
  5. Power outage Thanks god for ups!
    By Steve_C_NWales in forum General Chat
    Last Post: 11th January 2003, 00:01
