Volks AutosSky Insurance
    palfy86's Avatar
    Aug 2010
    Nottinghamshire
    238
    Broken Headlight Harness.
    Can anyone advise me on how to remove the main headlight wiring plug when the little tab where you push with the screwdriver has broken off.
    I tried the obvious approach of just trying to pull it off (im referring to the harness btw ) and prise it off with a screwdriver which is just chewing the plastic up tbh.
    Ive tried searching the threads and i can only find advice on how to replace the plug which is all well and good once the plug is off lol.
    Thanks in advance guys and gals.
    May 2013
    10
    Quote Originally Posted by Palfy View Post
    I used a scribe to remove mine like the picture below.
    palfy86's Avatar
    Aug 2010
    Nottinghamshire
    238
    Well fortunately stuart im at the dentist on thursday so while im there ill have a look on the tray and see whats there lol.
    Serious note though ill give it a try tonight and then once its off ill grind the catch down so it simply pushes on until i replace the plug.
    palfy86's Avatar
    Aug 2010
    Nottinghamshire
    238
    Just an update on this. I managed to get the plug off last night and i ground down the little catch on the lap so that i wont have the same problem again. CASE CLOSED lol.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Replacing damaged headlight connector body - guide
    I keep meaning to get round to this.
  1. Headlight Adjusters Broken?
    By karbonk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th December 2009, 07:01
  2. SO frustrating!!! Headlights still broken.
    By fran-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2009, 19:38
  3. Headlight adjusters broken - DIY job?
    By stevehaskew in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2008, 11:51
  4. does anyone have a broken S3 headlight?
    By jonS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2008, 08:38
  5. broken clips on xenon headlight
    By bpascua in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th October 2007, 13:14
