Badger5Monster Motorsport
Results 1 to 13 of 13
Thread: Jammed wipers
    Apr 2010
    168
    Jammed wipers
    Hi,just spent a couple of hours stripping my front wiper linkage to find the driver side was totally solid.After attempting to drift it out with a hammer and loads of wd40 i had to use a blow lamp which worked fine.My problem is that on re-assembly the driver side wiper blade now holds off the windscreen at about half stroke.I have taken all the bezels back off and tried adjusting the three linkage bolts with no success.Do you think that the initial attack with the hammer bent the linkage frame slightly.The spindle itself is ok since after cleaning and greasing it slid back into its housing perfectly.
    Jun 2012
    Teesside
    448
    i had this i found the linkage was slightly out of shape because of the use of the hammer, i bent the bottom of the arm slightly to counter act it
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
    Nov 2012
    Warwick
    41
    Just done this myself, but when gently drifting out the spindle the aluminium bracket actually broke off!! Had to glue it back on, which actually worked well in the end. The brackets should be at 90 degs angle to the spindle. It should be easy to see if they are bent? Is the wiper arm seated on the spline of the spindle properly?
    Tom.
    Apr 2010
    168
    could it be possible that when i hit the top of the wiper retaining nut with a hammer to shock the arm loose it actually bent the body panel downwards where the linkage bolts to thus changing the spindle angle.
    Aug 2011
    199
    Quote Originally Posted by stuhow3361 View Post
    Possibly. But that's a seriously strong bit of the car I'd have thought. I can't believe you did what you said you did though.
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,159
    I doubt it - I also bent the wiper arm mechanism when removing the spindles.
    I gave up in the end and bought a 2nd hand one from ebay that was freely moving.
    I stripped this one down with ease and re-fitted.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Apr 2010
    168
    sounds like i'll have to do this as well,tried numerous adjustments but the blade still lifts off the screen right in the middle of my sight line.
    Apr 2010
    168
    No other way to get them off.Tried a pullers initially but it only bent the frame as i tightened it.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I had this problem, albeit not after doing the mechanism, and I sorted it by bending the wiper arm slightly to apply more pressure to the screen in the middle.
    Aug 2011
    199
    For next time - Wiper Arms Seized Onto Spindle! has the solution!
    Apr 2010
    168
    Tried this as well but it does not make much difference - looks like a new wiper mech for me.On a different subject you seem to be the guy in the know,i'm looking for a roof spoiler for my avant and have seen many aftermarket ones on e-bay.Any suggestions as to best fit or oem only.
    Aug 2011
    199
    Me? I can't help there I'm afraid but I guess there are plenty of far more knowledgeable folk who will know. Quite interested in the answer myself as it happens.
    Mar 2008
    Dorset
    13,856
    Some people have bought these and found them 'ok'..
    Audi A4 Avant Spoiler | eBay
    OEM is approx £150 and probably worth the extra for fit etc, or by something like this:
    Audi S4 (A4) Avant Estate Tailgate & S4 Spoiler & Badge [B6, B7, Avant] | eBay
    ... and sell the rest on again.
  1. wiper mod
    By katanwara in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2004, 18:35
  2. New A3 Wiper Motor Replaced, Is the wiper too high
    By Rolex1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2004, 20:37
  3. New A3 Kaput Wipers
    By garethj in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2004, 22:12
  4. Stuttering rear wiper
    By ben in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2003, 22:15
  5. replacement rear wiper arms
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2003, 14:54
