AH FabricationsJMB Retrofits
Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By PetrolDave
  • 1 Post By quattrojames
Thread: RNS-d directions DIS
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Does anyone know if you can get the RNS-d navigation directions displayed in the DIS?
    I can't seem to find the answer via google but checked all coding and it appears to be ok. Anyone got any ideas?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    550
    Add GeoffDunk on Facebook
    i have been trying to get this to work and thought I had the coding correct but nothing came up. RNS-E and colur DIS.
    It turns out that you code it as you would then turn of ignition and then run car for some miles and it apears eventually so I have been told so am trying this this weekend on mine.
    Not sure if this is true but not been able to get it to work yet so will give it a try.
    Audi S4 quattro in Dolphin Grey Metallic, Silver leather, carbon inlays, RNS-E, 6 speed manual, electrically adjustable & heated seats, xenon headlights with power wash, cruise control, storage pack, 18" OEM RS4 wheels, RS4 ARB, LED lighting upgrade, FASH plus every bill since new.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Quote Originally Posted by GeoffDunk View Post
    I read that about the RNS-e but having to turn it off and back on to get it to display the directions seems like a right hassle and a complete bodge when it should just appear.
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    550
    Thats my point, it doesn't just apear. YOu need to drive the car apparently. I can only assume it has soemthing to do with the intergration with the car or something. I am trying it this weekend. My car is being worked on right now and when I get it back the coding for the RNS-e and DIS will be done and we'll see what happens.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Let me know how you get on.
    I have read that if you set the RNS-d (not sure if its the same on e) to Colour DIS screen (its normally set to monochrome) it works better on monochrome DIS. I've not tried that yet but its worth a look I think.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Are we talking RNS-D or RNS-E? - as the answer is completely different.
    If we're talking RNS-E it's just a case of getting the value in adaptation channel 62 of the instruments correct - and if you have a red DIS you have to turn the RNS-E off and back on after setting an active route (because of a bug in the red DIS firmware that Audi don't care about because they never sold an A4 with the RNS-E and a red DIS).
    If we're talking RNS-D then you also need the separate TMC tuner which also acts as a CAN converter between the Bosch CAN variant that the RNS-D "talks" and the Audi CAN variant that the car "talks".
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,467
    how do you drive it ?
    all you do is as above turn rns off then stright back on it works (red dis)
    if you have colour dis you have codeing wrong
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Some people have found that you have to do the coding/adaptation changes and then wait 24 hours - when it works.
    The best theory why this happens is that the CAN messages have a sequence number and in some cases you need to wait for this to "wrap-around".
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Where is the E coming from?
    There was no mention of a RNS-e. Its all about the D.
    The unit is fitted with a TMC.
    The radio, track and such information is displayed on the DIS.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    It's still needs to be coded in the cluster, adaptation channel 62 still needs coding on the RNS-D install with a TMC module
    1=radio
    2=telephone
    4=navigation
    so a value of 5 would be radio & navigation in the DIS.
    Dave's explanation was quite correct, it was the other posts which were confusing the issue, you started off posting about the D, the next poster said he couldn't get the E to work with colour DIS, and sometimes it doesn't work right away after coding.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Quote Originally Posted by s8craig View Post
    1=radio
    2=telephone
    4=navigation
    Cluster coding. Thought we did that. I'll double check it on Sunday.
    Thanks you and others.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Quote Originally Posted by ScottB5 View Post
    Read the second post in this thread.....
    ScottD3 likes this.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Quote Originally Posted by PetrolDave View Post
    Ok fair shout.
    S8Craig, done that it and worked a treat mate.
    I really thought we did it, o well it works now.
    Thanks.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Thanks Scott
    ScottD3 likes this.
  1. RNS-D retrofit DIS problems
    By cerips in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st April 2012, 10:58
  2. RNS-E and DIS retrofit question.
    By JAS11N in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th December 2011, 16:55
  3. RNS-e Directions on DIS
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th September 2009, 20:23
  4. does the rns e direction show on the DIS
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st July 2008, 22:20
  5. Rns-e & Red Dis
    By nick1966 in forum Major UK Events
    Last Post: 12th October 2007, 23:59
