    Jun 2004
    Surrey
    194
    Removing boot lining!
    I have searched the site and found no info, and also tried to remove the boot lining to change a brake light bulb but I give up.
    Help, help, help please!!
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    Re: Removing boot lining!
    No need to remove the lining to change a light bulb. There is a small circle in the lining behind the light unit, use a flat screwdriver to prise it open and you will see a nut or a torx screw in the hole. Undo that and the light unit will hinge out from the car.
    Removing the boot lining is a ***** of a job. The rear seats have to be removed and all!
