Chris NottVolks Autos
    dale86's Avatar
    Oct 2012
    361
    Driver seat broken
    Howdy the rear of my drivers seat has broken it's hanging off at the bottom it's the plastic part that is fastened to the rear of the seat. Has anyone else had this happen as it was the same on my 1.8t so I'm thinking it may be common and also is their a way to fix it ? Thanks
    Jan 2009
    150
    I had this, I welded the snapped lumbar support bar, protected the seat with alot of folded tin foil. Then fitted the seat back repair kit.
    This has all the details,
    Seat Back Panel - Broken
    dale86's Avatar
    Oct 2012
    361
    Thanks Gaz I have suspicion my lumbar had gone too now
    Jan 2009
    150
    That normally causes it. I took the seat out, trimmed the plastic covering from the lumbar bar, welded it, then used the repair kit on the backing. Worked brilliantly. I wasn't paying for a new lumbar part for £££.
  1. S3 Driver seat problems
    By RS-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2006, 20:43
  2. Creaky drivers seat
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th September 2006, 23:19
  3. Drivers seat wiring loom
    By Bongo163 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th March 2006, 17:12
  4. Drivers seat problem...
    By JoeInIreland in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th July 2005, 16:19
  5. My Drivers seat has the wobbles
    By Anito in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th August 2004, 16:26
