Volks AutosMonster Motorsport
    Jan 2013
    12
    B6 cabriolet new drivers door now nothing works - need wiring diagram please
    Hi guys, i have a b6 cab 2.5tdi i have fitted a new drivers door and when the new one turned up it already had the main wiring harness with it. Me being a complete div i've scrapped the old door with the loom in it.
    I've phoned audi and have a part number 8h1971029q but its on back order and i need to get this sorted asap.
    The loom in the door has all the correct plugs on it, it just doesnt work anything so i take it theres a few pins in different places were it plugs into the (A) post.
    Not sure where to even look for a diagram so wandering if anyone can help? thanks
    Nathan
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I'll look on Elsawin one evening this weekend if I can, they're normally quite complex so for a few quid it's worth getting your own copy off Ebay if you can.
    Jul 2007
    London
    3,250
    It looks like you either got a door from a car with manual window winders (on the rear !) or from a later 2003 on car. The wiring is the same just the pins need swapping in the connector at the door jamb ! You also need to make sure there are no broken wires in the harness before condemning the door loom !
    FOR SALE:
    Oct 2009
    Hull
    1,442
    yeah first thing I would be checking is the wiring in the loom to make sure you have no broken wires as its a very common problem
  1. Drivers Door sensor is not working ! ! !
    By dancarpy in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2013, 23:19
  2. Picture of drivers door with panel off needed.
    By hobo_mofo in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th November 2011, 09:12
  3. Audi A3 drivers side door lock not working
    By rick28 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2011, 01:35
  4. Drivers door won't open on my S3 :( Please HELP
    By SamiG in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2011, 23:17
  5. Audi A4 Cabriolet - Driver Door Module
    By Acidic32 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th June 2010, 12:34
