Sky InsuranceChris Nott
Results 1 to 14 of 14
Thread: Better Brakes?
    Aug 2011
    151
    Better Brakes?
    So - I've read all the great threads about fitting everything from Porsche brakes to S4 brakes to various slightly less exotic Audis.
    But all I really want to do is improve on the braking performance of a standard 2.0 A4 Avant - FSI - B6. This is just an ordinary road car, nothing special, no significant mods. Standard wheels etc.
    Discs are standard - and were replaced 2 years / 30,000 miles ago (before I bought it) with what I believe might be Genuine Audi, and it had new pads at the same time, although I've no idea what they are.
    How could I improve on the not especially wonderful brakes? Better pads? Lines? Brake fluid? (No idea when that was last changed, but the car was exceptionally well maintained so if it was on the schedule, it was probably done).
    Yes, it would be nice to put bigger discs on - but it's a balancing act between money and time and result.
    Thoughts appreciated. Thanks, Mike
    Jul 2007
    London
    3,090
    Get 312mm brakes from a v6 tdi or larger petrol engines...well worth the expense !
    FOR SALE:
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,076
    As Chris said above, 312mm would be a good upgrade.
    If your budget allows maybe even try a set of B6 S4 brakes!
    Aug 2012
    Darlington
    171
    another vote for 312's, costs buttons to do, is a very easy swap and makes a noticeable real world difference
    Aug 2011
    151
    Quote Originally Posted by AlexGSi2000 View Post
    Mmmmmm - B6 S4 brakes - - - aye, and the bigger wheels to go with them - - nice thought tho!
    312 - a little research finds refurbed calipers and carriers for £200 - then between £50 and £200 for discs - and £50 or so for decent pads.
    Mike
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,422
    312mm brakes. Paid £50 for a pair of used carriers off a 3.0 and £60 for new pagid discs and pads when there was an offer on.
    Noticeable difference to the 288mm previous version
    Mike
    Aug 2011
    151
    Seems I have to start searching for 312 carriers then!
    Final question - is it worth the extra to go drilled and/or grooved discs? Remember, this is just an ordinary road car.
    Thanks all - Mike
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,728
    Might be more like 25 past, it's mental here as all the nephews and neices are having a sleep over ha! About to jump in shower now.
    Jul 2007
    London
    3,090
    Quote Originally Posted by Mike_B View Post
    Thanks all - Mike
    I have a set of 312mm brakes, carriers and good discs. Pads could do with replacin but i have these as well. £150 for the lot posted...Groved discs clean the glaze of the pads but make more dust, drilled offer improved cooling but they often crack ! Solid discs are fine for a daily driver...
    FOR SALE:
    Aug 2011
    151
    Interesting - thanks - would you part with the carriers on their own? Calipers are fine and I'll go with new discs / pads for preference you see.
    Jul 2007
    London
    3,090
    The pads/discs are worthless on their own mate, everybody knows that ! If you happy to pay 150 for the carriers then i am game !
    FOR SALE:
    Aug 2011
    151
    ROFLMAO - You're a funny guy pal. I think you know the answer, but thanks anyway.
    Jul 2007
    London
    3,090
    No problem !
    FOR SALE:
    crazy88's Avatar
    West Yorkshire
    4,728
    Quote Originally Posted by crazy88 View Post
    What the hell, how did I post that? That was a text I sent...that could have been a lot more embarrassing!!
  1. Bigger/Better brakes for S3
    By Benjiman46 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2013, 11:28
  2. Bigger/Better brakes for S3
    By Benjiman46 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th March 2012, 09:12
  3. Anyone fitted better brakes?
    By dmaudi in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 7th February 2012, 11:28
  4. Needing some better brakes advice please?
    By Hendo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st September 2011, 22:01
  5. Which model VAG cars will give me better brakes?
    By munchkincoupe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th April 2011, 14:16
