Chris NottBadger5
Results 1 to 14 of 14
    glenandem's Avatar
    Sep 2012
    manchester
    530
    Part no request help
    Hi guys I'm after the part no for both sides complete driveshafts for my 2003 b6 avant 1.9tdi awx fwd manual if anyone can help so I can cross ref them!
    really appreciate it cheers glen
    glenandem's Avatar
    Sep 2012
    manchester
    530
    If nobody can help with part no,is it poss to get a free version of etka anywhere?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    5 or 6 speed gearbox?
    glenandem's Avatar
    Sep 2012
    manchester
    530
    Ooh what a nob! One of the most important points I should have mentioned!
    5 speed fella
    Mar 2008
    Dorset
    13,856
    I've just shut the PC down, I'll have a look for you tomorrow night.
    glenandem's Avatar
    Sep 2012
    manchester
    530
    Haha cheers fella!
    Mar 2008
    Dorset
    13,856
    For AWX
    Left = 8E0 407 451 GX
    Right = 8E0 407 272 S
    Numbers supplied in good faith, etc ....
    glenandem's Avatar
    Sep 2012
    manchester
    530
    Cheers fella really appreciate that but if u don't mind could you double check them as I'm getting the following which you have one listed?
    8E0407271S
    8EO407272S
    Jun 2012
    Teesside
    448
    Glen i have the saloon of your car same engine awx 5 speed, and i have the 71s and 72s shafts, just recently replaced one of them, so can guarantee compatibility of these part numbers
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
    Mar 2008
    Dorset
    13,856
    There's a myriad of options for Driveshafts in Etka, those part numbers I read are listed in my version for your car, and as always part numbers are given in good faith etc.
    If Dan can personally vouch for those part numbers then I'd go with them.
    glenandem's Avatar
    Sep 2012
    manchester
    530
    Cheers fella, can I ask y u replaced them?
    im at whits end with a vibration I've got from the front at most speeds but really noticeable on mway, steering doesn't shake atall and I've replaced engine mounts, dmf etc and now I'm thinking its got to be either driveshafts or worse gearbox although I put it in neutral on mway and have even turned engine off when it's quiet! And vibration still there, wheels all good too but would have thought they'd shake steering wheel so I'm just down to these two things now or I'm buggered!
    second hand driveshafts are cheap and only take ten mins to change do thinking I'm gonna try both of them see how it goes
    2,179
    This is what I have listed in etka July update 974
    8E0 407 271 S was dropped on 01/11/2011 and replaced with 8E0 407 451 GX
    8E0 407 272 S was dropped on 01/02/2012 and replaced with 8E0 407 452 GX
    glenandem's Avatar
    Sep 2012
    manchester
    530
    Cheers pal, wonder why they changed part no?
    2,179
    Change in OEM manufacture, rectify a design fault, change to one of the sub assembly parts or slight design change to make it compatible with other models, end of the day you never know unless it's a common fault like the well known B7 170 injectors.
  1. part number request can you help
    By marktdisport in forum General Chat
    Last Post: 1st January 2012, 14:27
  2. Part number request
    By mwstewart in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2007, 10:44
  3. ETKA part number request
    By jeremygs in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2007, 20:50
  4. Water Pump part no. request.
    By jojo in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2006, 18:14
  5. Part number request
    Last Post: 10th October 2006, 17:58
