Sky InsuranceVolks Autos
Like Tree1Likes
  • 1 Post By AlexGSi2000
Thread: S4 brakes onto tdi ?
    audilad9's Avatar
    Jan 2013
    Highlands
    240
    Hi all, I bet this has been mentioned before on here but I don't see it and its urgent.
    I want to fit B6 S4 front brakes to my 1.9 tdi. My main question is do the B6 S4 caliper carriers bolt straight on in place of originals ? Are there any clearance issues requiring spacers ?
    I assume I can use either my original hoses or the S4 ones, I would like stainless braided ones.
    Is there any gain in using the S4 master cylinder/servo if even possible ?
    Lastly, my ABS seems to want to cut in unnecessarily, could this be clogged teeth on the CV ABS ring ?
    Many thanks.
    2004 B6 A4 1.9 tdi quattro sport. Ebony black. S line RS6 style wheels. Black diamond drlled and grooved brakes all round, predator pads.
    K&N 57i induction. EGR delete. Custom Remap.
    LED lights. Ambient lighting. Factory armrest. B7 aero wiper upgrade. Team Heko wind deflectors.
    Wanted : Rust free wings. S4 brakes. Aluminium mirrors. RS4 RARB. Clutch upgrade.
    Just fitted 235/40/18 Dunlop Sport MAXX RT's, hoping for great things !
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,076
    Im pretty sure all suspension uprights are the same on the B6, so in my opinion, yes - they should bolt straight on.
    The S4 calipers I purchased for my 2.5 came with the hoses from the S4, these connected straight to the union in the wheel arch.
    I would fit S4 brake lines due to different positioning, the standard brake hose may fit, but may not necessarily be long enough.etc
    I didnt touch the servo / master cylinder - but the difference compared to the standard brakes was night and day!
    In regards to the ABS, its most likely a sensor - if you use VCDS, it should show you which one.
    audilad9's Avatar
    Jan 2013
    Highlands
    240
    Thanks Alex that's the answer I was hoping for. I assume you have used S4 carriers ? I will buy the S4 setup now. Its at to good a price not to.
    With the ABS, I sort of ruled out a sensor as I thought the light would come on which it doesent, just that I can feel the ABS begin to pulse under moderate braking when it definitely should not. Unfortunately I don't have VCDS yet anyway. Must invest !
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,728
    I've just had my rear brake pads and discs replaced as they had seized. The mechanic was saying it can cause the abs to come on slightly due to them being seized and basically getting confused? I felt a slight vibration/ judder through my pedal which does seem to have gone now.
    audilad9's Avatar
    Jan 2013
    Highlands
    240
    Theres an S4 front brake setup on ebay which includes spacers "to allow the caliper to clear the wheel" ?
    Audi A4 S4 Quatro Front Brake Conversion | eBay
  1. help please - S4 BRAKES onto 2.0 TDI
    By doug.p in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd September 2011, 09:21
  2. Fitting S3 DSG pedals onto TDi
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st March 2011, 11:37
  3. New S4 Brakes on TDI
    By Caesium in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th April 2007, 15:55
  4. A8 4.2 brakes onto 3.7
    By excursion in forum A8/S8 forum
    Last Post: 2nd April 2004, 14:54
  5. s4 brakes onto a A4 tdi???
    By andyollie in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th March 2004, 14:00
