Innocence80
I am looking to swap out my standard stereo (because it's crap!) and replace it with a sony unit, what sort of connecting harness will I need for the wiring. Hoping there is a plug and play solution.
You have to take the side panel out of the boot to see the amp, takes seconds and goes back in to place easily.
You will need the adaptor that converts the outputs of the Sony to match the inputs of the Audi/Bose amp, adaptor for the aerial, a 12v switched live from the fusebox or similar.
Does your Sony unit have RCA outputs?
ALL Audi OE head units use an external amp:Well I don't have an amp.
- if you have Bose then it's a 4 channel amp
- if you don't have Bose then it's a 2 channel amp for the rear speakers with the front speakers connected directly to the head unit.
