Sky InsuranceJMB Retrofits
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By adamss24
Thread: recommended live dyno tuners
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    Im after getting the bv43a turbo,my remaper says im better to get it remaped again but dynotuned as its mored complex with a biggr turbo.
    Any ideas guys?
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    Jul 2007
    London
    3,234
    Out of the box the bv43 is a very potent little turbo which makes it very sought after as it's plug and play on the inline 4 cyl. diesel engines. I prefer on the street logging as you cans see what the turbo/map can do but live dyno is safer and more convenient ! The trouble with live dyno it's costly and i would spend money elsewhere !
    I had mine for a few k on a b6 audi avant with a freshly rebuilt engine but sadly the single mass flywheel conversion caused the syncro's to break in the 5 speed 01X gearbox (****ty box to have in a diesel!) as soon as i took it on a spirited drive around M25 ! The base map was not finished but, if you want to try-it then i can upload it on your ECU and you can live with it till you have your's done on a dyno !
    At the time getting a SMF was the only way to upgrade to 240mm clutch and as the flywheel was damaged i had no choice but to fit the grabby Southbend stage 3 clutch i saved for a special project ! Out of the box the bv43 is a nice little turbo, a little sow to build speed from 80 to 100 but very quick from 100-130 Mph ! Make sure yours brakes and suspension can handle the power hike, in my case i found the FWD a bit light and twitchy after 120Mph even though i have uprated springs/shocks and rs4 rear ARB...
    FOR SALE:
    Jul 2007
    London
    3,234
    FOR SALE:
    Jul 2007
    London
    3,234
    SmoothAssault likes this.
    FOR SALE:
    Mar 2013
    Near Oxford
    403
    R-Tech, it's a bit of a drive but well worth it.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    A little slow to build up 80-100, thats were i want the power, im very happy with my map at the moment,boost is everywhere,i love the sound of 100-130 but id be at that al day n end up with no license!
    Because of my map now will this turbo still produce the same boost?
    Im after more power and torque.
    Is upradeding injectors going to do anythink?
    Also what about a boost gauge on the bv43 with my map,would i be able to get some extra power as its a bigger turbo?
    Jul 2007
    London
    3,234
    A bigger turbo will always be a bit laggy compared with the gt1749va you have on the car at the moment. The nozzles you have are tiny and need loads of duration in order to inject more. Getting larger nozzles is the way forward, more fuel injected equal's more exhaust manifold pressure so you can drive larger turbines and create more boost. If it's midrange you after then a hybrid gt1752v might be more suited to your goal. The bv43 is smoother, it builds boost more gradually but it will have more top end without choking the turbine. Going bigger is always going to be a compromise and if you can live with a little lag (2-3 sec) then fine... Just remember the larger turbo's were designed for larger crossflow engines with 16 valves or more...and newer injection system: Siemens PPD or CR.
    FOR SALE:
    Stu-pid's Avatar
    May 2013
    80
    Where does everybody keep getting these turbos from? I want one
    Jul 2007
    London
    3,234
    They are rather rare, fitted on a few 2.0 tdi engines from 2006 to 2007...very rare ! I want £400 for mine, bought it brand new in the box, only done 2-3 k in it before the gearbox broke syncro's !
    FOR SALE:
    Stu-pid's Avatar
    May 2013
    80
    Wish I had a spare £400 rite now I would take it off ur hands
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    Cheers for the info chris,did u get the txt i sent u?
  1. Recommended tuners South West - Badger 5
    By AJC in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2011, 19:04
  2. recommendations pls: bodyshop and tuner
    By 23e Heure in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th January 2011, 00:09
  3. Recommended digital TV tuner?
    By Foxmeister in forum In-Car Entertainment
    Last Post: 26th July 2009, 18:34
  4. Digital TV Tuner Recommendation? and Antenna Placement?
    By cooni in forum In-Car Entertainment
    Last Post: 30th April 2008, 09:11
  5. Friends new cd/tuner / Permanent live ?
    By Amchlolor in forum In-Car Entertainment
    Last Post: 18th October 2005, 10:35
