EM TuningAH Fabrications
Results 1 to 11 of 11
    Feb 2012
    Glasgow
    191
    Ticking + no indicators or wipers
    Hi guys. Bit of a problem. Started the car up this morning and there was quite a loud ticking noise from behind the dash in the area of the fuse box and also the windscreen wipers and indicators don't work. I have had a look behind the fuse box and as expected there are a bunch of relays in there. I suspect one if them is the problem but any hints or pointer would be great.
    Update:
    Cables and relay panel behind fuse box were wet. 2 things is it likely just to be a faulty relay or am I to prepare for the worst..... Secondly any idea where the water would be coming from?
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,197
    have a look inside the ecu box, that is a known leak spot at the drivers side, also if there is water in there check that the drain holes 1 under battery and 1 under brake servo are not blocked and everything is swimming in water
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,927
    if its wet your cem will be shot
    open it up try to dry may be lucky
    its the black box to the right of the steering wheel behind the bottom cover with a few big plugs in it
    iv changed a few in the past and as above take ecu cover off make sure its not wet in there the seal may have gone and letting water in.
    Feb 2012
    Glasgow
    191
    Thanks for the input guys. What is a cem? More importantly how much are they?
    bez101's Avatar
    Jul 2008
    7,927
    it runs the wipers lights etc
    they range from 30/120 on ebay no idea how much from audi.
    if it is that make sure yu get the correct part number end letter is important for it to work
    Feb 2012
    Glasgow
    191
    If it controls the lights then I might be ok as the lights still work?!?
    bez101's Avatar
    Jul 2008
    7,927
    Quote Originally Posted by IanFM View Post
    it can make diffrent things not work tho
    open it up nad take it from there
    S3 Johnny's Avatar
    The grass isn't always greener
    Sep 2009
    Somerset
    211
    Bet it's your hazard light switch. Did it on my S3 and turned out to be the hazard switch.
    Worth a try
    Johnny
    S3 03, Ming Blue, Genuine RSTT's, BOSE, Sunroof, Factory Lowered, Centre Armrest, Greencotton filter, REVO, Forge 007p (Yellow Spring), Black DiamondDrilled and Groved Front Disks and Pads, Custom FMIC withYellow pipes SOLD
    S3 GAZ's Avatar
    Dec 2006
    Renfrewshire Scotland
    299
    Sounds similar to a problem I had which mysteriously disappeared and has never came back.
    http://www.audi-sport.net/vb/a4-a4-cabriolet-s4-forum-b6-chassis/152046-major-electrical-woes.html#post1516997
    Major electrical woes.
    Feb 2012
    Glasgow
    191
    Looks like bez might be right have just pulled the electronics control module and sure enough it is a bit wet. Although it looks like it has been that way for a while. So drying it out just now and will see how that goes.
    If I need to replace it apart from making sure I get the right one with the correct letter is it plug and play other than that?
    bez101's Avatar
    Jul 2008
    7,927
    water may have been geting in there for a while
    dont forget to find out where the water is comeing from tho
    and all depends for plug an play if new needs codeing
    second hand may or not need codeing changed all depends on options of the car.
  1. Replies: 8
    Last Post: 30th September 2011, 20:16
  2. HELP....indicator and wiper stalks stopped working!!
    By S3 Rav in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2011, 21:44
  3. ABS light on = no lights, indicators or wipers. HELP
    By bertracoon in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th August 2010, 19:00
  4. Audi A6 1.9TDi Indicator & Rear wiper issues
    By chris2009 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th April 2010, 22:55
  5. anyone replaced indicator/wiper stork?
    By TDI in forum Volkswagen and other VAG
    Last Post: 23rd June 2008, 21:03
