EM TuningSky Insurance
    dale86's Avatar
    Oct 2012
    356
    NO boost in first on start up !
    Hi all sometimes when I first start my car it has no boost in first gear then when you hit second it seems fine and after you get going it doesnt reappear until the next day or so its a 1.9tdi 130. Could this be sticky turbo vanes ?
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    626
    I'd give the mr muscle a go for starters.
    There is a how to around here somewhere,
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    dale86's Avatar
    Oct 2012
    356
    Yeah im defo gona give that a go but I was wondering if it could possibly be a boost leak too ?
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    637
    Check your vacuum pipes. Check the black and white one way valve on the vacuum pipes. See if your N75 is working.
    Most importantly plug the computer in and see whats its trying to tell you.
    dale86's Avatar
    Oct 2012
    356
    Ok will do thanks for the reply are the vac pipes on the drivera side as I have been getting a loud hissing noise which continues a bit after the car is turned off from under the bonnet on the drivers side up near the airbox.
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,152
    Is this not a safety feature to help look after the turbo when the engine is cold?
    On my Ibiza Cupra, the engine prevented boost for about a minute after start-up.
    The hissing sound from the drivers area may be your air-conditioning - mine does the same.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
  1. S3 sounds like a jet engine on first start up
    By viper6 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2009, 22:32
  2. First start, no turbo
    By dhyndi in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2008, 15:20
  3. Strange 'Jet Engine' noise on first start up...
    By spuddie007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd January 2008, 21:43
  4. head unit problem on first start up
    By peakey in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2007, 20:53
  5. Car doesn't start first time
    By ImS3ola in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2004, 19:14
