NO boost in first on start up !
dale86
co durham
Hi all sometimes when I first start my car it has no boost in first gear then when you hit second it seems fine and after you get going it doesnt reappear until the next day or so its a 1.9tdi 130. Could this be sticky turbo vanes ?
I'd give the mr muscle a go for starters.
There is a how to around here somewhere,
Yeah im defo gona give that a go but I was wondering if it could possibly be a boost leak too ?
Check your vacuum pipes. Check the black and white one way valve on the vacuum pipes. See if your N75 is working.
Most importantly plug the computer in and see whats its trying to tell you.
Ok will do thanks for the reply are the vac pipes on the drivera side as I have been getting a loud hissing noise which continues a bit after the car is turned off from under the bonnet on the drivers side up near the airbox.
Is this not a safety feature to help look after the turbo when the engine is cold?
On my Ibiza Cupra, the engine prevented boost for about a minute after start-up.
The hissing sound from the drivers area may be your air-conditioning - mine does the same.
806
941
547
T0m
