AH FabricationsEM Tuning
    Aug 2008
    Leeds
    152
    Question ABS Problem - Can You Get Replacement ABS Rings on their own?
    Hi there,
    My car has recently developed an issue with the ABS which is due to corrosion of the ABS rings due to age/wear and tear..
    Does anyone know if the ABS rings themselves (the toothed rings that are on the end of the drive shafts at the front) can be purchased on their own or do they only come as part of the hub or drive shaft assembly?
    Obviously I would imagine that if they only come as part of the drive shaft etc it would be considerably more expensive.
    Any info would be much appreciated.
    J
    glenandem's Avatar
    Sep 2012
    manchester
    527
    hi, not sure if you can get them separate for the audi's but ive fitted them to other makes of cars.
    couldnt you get the cv joint instead of a full driveshaft?
    one final thing, im not sure how corroded your joint is but in the past ive just got a wirebrush and managed to clean the grooves on the abs ring!
    have you put a multimeter on it and made sure its the ring not giving the right signals?
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    253
    It's called a reluctor ring. If the ABS is kicking in, my money is on one of the rear rings splitting. These are expensive - personally I'd go for the Ebay ones. Cheap enough to replace every few years.
    ABS Reluctor Rings - Audi cars
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
  1. Can you get replacement front hub bushes....
    By TYphoon GB in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th October 2012, 22:11
  2. Can you get TV on iphone?
    By willnabby in forum General Chat
    Last Post: 20th June 2008, 13:02
  3. can you get the led lights for the s3?
    By edward_harris in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th April 2007, 10:29
  4. Can you get a MF wheel fittewd to a05 A4??
    By skooby in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd November 2006, 09:07
  5. Can you get tuning boxes for SAME tractors??
    By smanning in forum Diesel forum
    Last Post: 17th July 2003, 09:55
