JMB RetrofitsEM Tuning
Results 1 to 12 of 12
    Oct 2010
    446
    Just installed rnse
    I haven't had my oem stereo for a while now. Just installed my new rnse an wanted to check that the stereo slightly overhangs the climate control? Ie not flush?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    On an A4 unit the stereo sits over the air con, it is not flush.
    Oct 2010
    446
    Fair enough.
    Oct 2010
    446
    Also. Are the directions suppose to show up on the top fis on clusters?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    If you have a RED fis then it's a bit hit and miss, with the colour FIS it can take upto 24 hours to appear, if everything is coded correctly, radio, instrument cluster etc the directions can be made to appear on the RED fis by powering off/on the RNS-E when a route has been selected i'm led to believe.
    Oct 2010
    446
    Hi Craig thanks. I am unsure what coding I need to do I added 4 to instrument coding but unsure on radio or
    Navigation.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Well the ross-tech wiki is a good place to start.
    Oct 2010
    446
    Directions now work on cluster!!
    Mav190sline's Avatar
    Jul 2011
    Surrey/Hants
    83
    Hi. Sorry to hijack but I did this retrofit quite a while ago but do not have directions on red dis display. How do I get it to work
    Mark
    Oct 2010
    446
    Set a route, start engine, stop route then restart route. That should work. I also have a dis stalk so can choose to display it or not.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,533
    Quote Originally Posted by vwgtiking View Post
    But that only works AFTER you've changed the value in adaptation channel 62 of the instruments, see Audi A4 (8E) Instrument Cluster (8EC/8ED/8HE) - Ross-Tech Wiki
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Jul 2011
    Surrey/Hants
    83
    Thanks. Will try that later
  1. Just installed a PORSCHE BBK with some goodies...
    By mrgicm in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th May 2014, 21:34
  2. Just installed Recaro Pole Positions...LOVIN THEM.....
    Last Post: 17th July 2010, 09:53
  3. Installed rnse today, but little problem
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th December 2009, 21:20
  4. RNS-E Just Installed! - Few Questions...
    By Silky-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th May 2009, 16:45
  5. Just Installed
    By chesterdog in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th January 2005, 13:37
