    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,108
    Boot open warning
    Hi all..... my DIS is warning that the boot is open even though it's not.... given the door a good slam and made sure but the warning is still there.... I can't see any obvious switch anywhere .... is there a common fault to check for ?? broken loom perhaps ?? anyone know where the switch is ?? car is 2002 TDi Avant need to sort it as it overrides all the DIS info whilst it's illuminated
    Cheers peeps
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Oct 2009
    Hull
    1,440
    The micro switch is in the lock
    Pretty sure you can remove it
    It's not the wiring as when that goes it shows as shut all the time as I have had it
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,335
    Happens a fair bit to me, just usually shut it a few times and it goes or have the key in and out a few times, guessing you've done this a fair few times though so as you and Stu say probably just need to remove/replace the switch in the lock or have it coded out (although then obviously you loose the ability to know when it's open).
    Mar 2013
    Near Oxford
    403
    I'd spray loads of WD40 into the mech, see if that sorts it out.
  1. Boot Open Warning
    By WorkInProgress in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2013, 20:49
  2. should my car have a boot/door open warning light?
    By ALPINE in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2010, 14:51
  3. Boot opening button
    By landylout in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th May 2007, 20:10
  4. Avant boot open!!!
    By WilkoS3 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th June 2006, 13:26
  5. Door open warning help
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2005, 22:11
