AH FabricationsSky Insurance
Results 1 to 7 of 7
    Oct 2012
    425
    DIY Air con re gas / top up
    Just out of interest has anyone ever tried using one of these cans i keep seeing in Halfords? Are they any good do they work?
    Point_Audi's Avatar
    Vorsprung durch Technik
    May 2010
    Ireland
    553
    Quote Originally Posted by Ian2012 View Post
    I used one before but didn't get it in Halfords. It is easy to do yourself, another forum member put together this useful guide:
    Air Con Re - Gas
    Hope this helps.
    A4 B8 2.0TDI S-Line Executive
    Events Moderator
    Ireland/Northern Ireland
    glenandem's Avatar
    Sep 2012
    manchester
    527
    Hi pal, I've never tried one but from my days if working in a garage and using ac machines, I imagine these DIY ac are just for topping the lost gasses over time u lose, i don't know how much they cost but I think you'd be better taking it to a garage or a mobile ac man for a full ac regas with a good vacuum to suck any moisture that might have built up over time!Our garage used to sell regases on the idea of bacteria that breeds in ac systems apparently it does with the cold conditions etc.
    I once vacuum'ed my own car for an hour and half and the system was just above freezing having a nice patch on the windscreen!
    Wish I had access to an ac machine now my a4 needs a regas when I've replaced the g65!
    Aug 2013
    Hey, did this at halfords last week.
    Like having a new air con system!
    Cost £35 and still have half a canister I can use next year. Obviously only any good if it is a re gas not compressor issue.
    Mar 2013
    Near Oxford
    398
    does this add oil to the system? You can get a full proper regas for around £30 so seems a bit pointless to me.
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,145
    I was told to stay away from these DIY kits as they contain chemicals that may degrade / damage the air-con system over time.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    606
    Also if theres a problem its wasted money and gas. Kwik fit (did) ? have policy with the ac ,if thers no change in temp then no charge.
    Ive been there twice,1st no change in cool air,no charge.
    2nd time changed pressure sensor,still no temp change=no charge.
    Thinks its new compressor time :-(
  1. Air Con Re-gas
    By Pipsqueak in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st March 2012, 11:49
  2. Air Con Re - Gas
    By john2garden in forum General Technical / How To
    Last Post: 22nd August 2006, 16:47
  3. Air con gas
    By steve1975l in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2006, 22:04
  4. Intermittent start Problem and Air con gas.
    By imported_Astwell in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th September 2004, 20:23
  5. Air con gas
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2004, 08:01
