Sky InsuranceEM Tuning
Results 1 to 28 of 28
    technics100's Avatar
    Feb 2004
    Co Antrim
    771
    headlights are apaulling, is this normal
    I have a 2002 tdi 130bhp and the lights are awful to say the least, is this normal? When side lights are on the only light that is lit is a bulb under the main bulb see pic 1
    When normal driving lights are on (dipped lights the small light besides the large lights up aswell. see pic 2
    When full beam is on only the large light is lit. pic 3
    I thought that the car might of had dual filament bulbs that would of lit when on normal driving lights...
    is this normal...or any ideas how to upgrade the quality of my lights, there verging on dangerous at night and i'm driving with my spots on, to give me extra lights
    cheers
    Sep 2005
    Hants
    21
    Re: headlights are apaulling, is this normal
    You could upgrade the bulbs as the stanadard ones are not very good,
    You may have a fault when switched to main beam as I think all 3 should be on in this mode, The whole road will light up when my main beam is on, i have upgraded my bulbs though.
    Nov 2004
    London UK
    2,614
    Even with the bulb upgrade i am not that impressed....it is better but still awful compared to other cars i have driven. Audi sort your lights out!!!!
    JohnBoy's Avatar
    Jan 2004
    Crawley, West Sussex
    85
    Yep I agree. The lights on mine a crap - dimmer than a glow worm's armpit
    gizze's Avatar
    Dec 2003
    Norfolk
    615
    I think it is the projector style lense on them, cuts out too much light for a regular halgen bulb, look nice, but doesnt do the business.
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    Xenons are great! [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Nov 2004
    London UK
    2,614
    Yeah rub it in mate [img]/ubbthreads/images/graemlins/lol.gif[/img]
    The911SC's Avatar
    Sep 2003
    1,032
    Seriously though, I have the standard lights on my A4 and although not nearly as good, I havent found them too bad having changed the bulbs to bosche blue.
    One thing I am surprised at and will check is that you seem to indicate that your ordinary main beam goes off when on high beam?.
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    Technics100,
    Looks like you've got a fault. All 3 lights should be on when you're on full beam.
    Jul 2005
    scotland
    397
    any idea how to change the level of the headlight?
    Feb 2004
    Co Antrim
    771
    There is the knob inside the car beside the headlight switch, but also a 6mm plastic allen head adjuster on the headlight itself. you should be able to adjust it here. I did mine and they have improved a bit. Also changed the dip bulbs for xenon filled ones..
    Jul 2005
    scotland
    397
    cool cheers, dont fancy needing to remove the headlights to change the bulb tho [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Nov 2004
    London UK
    2,614
    [ QUOTE ]
    [/ QUOTE ]
    It might look daunting but its pretty easy just take your time loosen the bottom too screws do NOT REMOVE just loosen and remove the top ones and they just slide out with a little side to side coaxing. Make sure you place something like a cloth under the light as its coming out so as not to scratch your bumper. After you do it first time you will wonder what all the fuss is about mate.
    Jul 2005
    scotland
    397
    its just getting something to reach the bottom 2 screws
    Nov 2004
    London UK
    2,614
    I just use a one of those screwdrivers with the small hexagonal slot shapes and various screw bit heads which you insert at the end...with it is also an extension piece which can be used ....B&Q or and other hardware place should have them.
    Try this http://www.maplin.co.uk/Module.aspx?...ges&doy=search
    Dec 2003
    Clarkston, Michigan USA
    247
    If you want all the lights to turn on when you hit the high beams then you can recode your electrical control module using Vag-com.
    Also since you have a 2002 you can recode it so that you can turn your fog lights on while your small city bulb is on.
    imported_Macduff
    [ QUOTE ]
    [/ QUOTE ]
    Fog lights. Also known as [img]/ubbthreads/images/graemlins/swear.gif[/img] lights. At this time of year all the idiots start using them and they are bloddy annoying. The name alone whould give a hint as to when to use them.
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    is this a london thing??
    Dec 2003
    247
    [ QUOTE ]
    [/ QUOTE ]
    In the States, the small bulb is referred to as the "city bulb". The North American spec headlights use the amber turn signal lights as "parking lights" when the headlight switch is turned to the first position.
    Some people in the States turn on only their parking lights on + fogs during the dusk/dawn time when low beams are too bright. Any other time I keep my fog lights off, unless during foggy conditions.
    Miller's Avatar
    Dec 2005
    S Wales
    13
    First look at this site, seems good!
    Dipped beams are hopeless on my 2000 Avant particulaly for m'way driving, main beam is OK. I've adjusted as high as they will go from inside the car, I will try some brighter bulbs for the dip; it looks as though you can just remove the covers inside the the engine bay to change the bulb.
    What type and wattage is advised for the dipped beam bulb?
    griffj's Avatar
    Oct 2005
    chester, cheshire
    105
    if you think the headlights on the A4 are poor (and mine are i have to agree) you should try driving a 2003 vectra (the wifes car) they are so poor ive had it back to the dealer a few times to try and sort it!!
    Aug 2005
    UK
    14
    I only had my 2002 A4 for a month before deciding that something had to be done with the headlights so purchased a HID kit to replace the main beam ....
    WOW ... what a difference it makes, the beam pattern is still the same so it does still seem a little low but the bright white light from the HIDs really illuminate the road well, traffic signs and speed cameras appear visible from miles away now.
    Now that I've found a place that is selling really good quality Korean HIDs for a reasonable price I might also swap my high beam too :-) (HID main beam makes my SilverStar High beam bulbs seem yellow)
    The price of HID kits does put a lot of people off, along with the thought of fitting them but my set only took an hour to fit, gives 3 times the light of a standard bulb and only uses 60% as much power !! and fingers crossed they will last the lifetime of the car.
    If you want better lights then you could do worse than fitting a HID kit...
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    Which kit did you fit and how much?
    Aug 2005
    UK
    14
    I fitted a set of Pilot 6000k HIDS that I bought from a guy in Birmingham for 185.
    A friend of mine is now importing them direct from the manufacturer in Korea and can sell them at about 145 (postage included) for a pair of H7s, they are 6500k (so really bright white light)
    Pictures of my before and after can be found at HID Example
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    i fitted the 5000k as i found the 6000k too blue
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    Have you got anymore details?
  28. #27
    Aug 2005
    UK
    14
    My friend has put some details about the HID kits he is selling on his personal web page [click here]
    This shows a few of the cars that he has fitted the HIDs to along with a picture of the actual kit.
    His email address is on the page I think so please contact him if you have any questions.
  29. #28
    Jun 2003
    World of my own
    9,813
    Anorien, just looking at your before/after page, very impressive.
    Do they really make the road look like it's been resurfaced? [img]/ubbthreads/images/graemlins/lol.gif[/img]
