Volks AutosMonster Motorsport
Results 1 to 8 of 8
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    547
    Add GeoffDunk on Facebook
    B5 perches on B6 S4
    I have heard and read so much about B5 perches. I am not 100% on exactly what they are, I assume its something the spring sits on (please correct me if I am wrong), hence lowerign the front of the car very slightly.
    Can this be done o nthe B6 S4 also. I am now about to have some front suspension work done and would be keen to sort this job while the front 2 corners are stripped out.
    Any ideas?
    Audi S4 quattro in Dolphin Grey Metallic, Silver leather, carbon inlays, RNS-E, 6 speed manual, electrically adjustable & heated seats, xenon headlights with power wash, cruise control, storage pack, 18" OEM RS4 wheels, RS4 ARB, LED lighting upgrade, FASH plus every bill since new.
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    547
    All those who have gone on about B5 perches?? Has no one any idea on this?
    Feb 2013
    Wiltshire
    345
    Yes, the springs sit on a plate on the front dampers. This plate on the b6/b7 are higher than the one on the b5. Swapping them over drops the car slightly without affecting dampers or the springs themselves. I have a set ready to go on my b7 s4 (will work perfect on the b6 too). Its a well worth doing mod if you dont like the tractor look
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    547
    Cheers RicoStuart1!!
    parts ordered!
    Dec 2006
    barnsley
    1,013
    yes you can do this but it alters the camber on the front of the car ... i would try and do similar on the rear or you could end up with
    funny handling as your not altering the camber on the rear
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    606
    Quote Originally Posted by dualmono21 View Post
    you are partly right,but no camber at front if anything,get ur tracking done,it will only lower front around 15-25mm but level the car better as the fronts a little higher than the back.
    I wouldnt worry about the rear its really minimal effect on the rear!
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. KRAPtuning custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    Dec 2006
    barnsley
    1,013
    the front camber on an s4 is adjustable by looseneing the subframe bolts and moving the subframe
    not sure about an a4 but its definately adjustable on s4,s
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    547
    Front camber is adjustable on the S4. Once fitted along with front bushes and other service items the car will be 4 wheel aligned anyway so it'll be spot on.
    The car currently sits very level, not high at the front at all. I just want to bring it down that 10mm or so with this easy conversion just to lower the centre of gravity and improve handling, with the 4 wheel alignment done after the fitting it should be spot on.
  1. I'VE HAD MY B5 SPRING PERCHES FOR 8 MONTHS, are they hard to fit ?
    By holmefield in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th March 2014, 12:35
  2. B5 spring platform (perches) + other parts for B6
    By jonny_mcc in forum A4/S/RS Parts
    Last Post: 14th June 2012, 20:14
  3. Advice please help. Part numbers for B5 spring perches
    By jambofuz in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th April 2012, 17:30
  4. Coilovers Installed, Rear Perch Seized
    By ChrisFurlong in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd July 2011, 22:49
  5. Front Shock Perch
    By CMD in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th February 2011, 09:48
