    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    2.5TDi Engine & Gearbox Mounts
    After 155,000 miles, the engine has begun to feel a little "loose" and bouncy.
    I noticed this the other day when changing the oil filter, loosening the top of the housing the horizontal movement of the engine seemed a little too much.
    I was wondering how difficult the side engine and gearbox mounts are to change - I am planning on doing the front snub mount this weekend, I believe the front needs to be in service mode?
    Many thanks!
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,713
    Im sure you can surport the engine from underside and unbolt the mount brackets for the engine mounts,
  1. Engine/gearbox mount fitting guide.........
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2013, 11:46
  2. engine and gearbox mounts???????
    By Big Bang Yam in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2013, 15:40
  3. Engine / Gearbox mount problem?
    By duffy78 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2012, 10:40
  4. Timing belt and engine / gearbox mount
    By nky_84 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2010, 21:57
  5. Would a 2.5TDI engine fit into an A3?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2006, 15:07
