EM TuningJMB Retrofits
Thread: B6 Error Codes
    waqeezee's Avatar
    Jul 2013
    7
    B6 Error Codes
    Hi guys,
    I recently checked my car for any error codes & I found 5 engine codes...
    17536 - Fuel Trim Too Lean (Bank 1)
    16500 - Engine Coolant Temp Sensor (G62)
    18017 - Crash shutdown activated
    17947 - Clutch pedal switch (F36) Implausible signal
    18010 - Power Supply Terminal 30 (B+)
    I did some research to find out what they are but was wondering if anyone here may have come across any of these and would know the cause of the problem & what to do to fix them.
    Any help would be great... thank you.
    waqeezee's Avatar
    Jul 2013
    7
    ... also had the following code when running ABS diagnostics:
    01826 - Steering Angle Sensor (G85) Voltage Supply Terminal 30
    Oct 2012
    424
    I would be tempted to clear them and see what comes back, i have had this once or twice where the car has had brain fart cleared them and they have never come back
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,524
    The 18010 and 01826 suggest that at some stage the battery was disconnected.
    I agree with Ian2012 clear them and see which, if any, come back.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
  1. Error code 00519
    By Jules in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd August 2005, 12:18
  2. error code 00575, and sqealing noise
    By lowrider786 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2005, 23:38
  3. S4 Error Codes?
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th April 2005, 19:47
  4. Error codes!
    By S4ZippyZoo in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2004, 12:43
  5. Flashing error code- "1n 1"
    By randallons in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th October 2004, 12:27
