EM TuningAH Fabrications
Results 1 to 9 of 9
    Jun 2006
    UK
    121
    Calling all 1.9TDI 130PD owners!
    Just a quick question, what RPM does your car idle at? Mine sat at 882 RPM which I thought was a bit high so I was playing around with VCDS yesterday and managed to drop this to 800 RPM. Much quieter and must surely save fuel? I could drop it lower but then it starting running lumpy. Do you think 800 RPM is okay or should I raise it again?
    Phil
    May 2012
    RETFORD, NOTTS
    1,718
    10% reduction in rpm 10% of the time, (when idling) isnt likely to save a lot of fuel. But if it works for you...
    Mine currently doesnt idle at all!
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,076
    I wouldnt personally mess about with idle speeds. They are set at default for a reason.
    You may even find that lowering the idle speed by 10% may even increase fuel consumption, as it may be easier for the engine to idle at a slightly higher speed, thus use less fuel.
    Also, if you take it too low, the engine may expirience abit of difficulty when ancilleries are turned on (air con pump, alternator load.etc)
    Aug 2012
    Darlington
    171
    Quote Originally Posted by AlexGSi2000 View Post
    This and all day this ^^
    Jun 2006
    UK
    121
    Very good point, I have yet to try it with any ancillaries switched on but I suspect some lumpy running. I think I might just change it back tonight!
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,209
    My 2.5 idles at 800
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,090
    anything that makes it quieter on idle is good by me..... mine sounds like a bloody tank..... what settings did you alter ???
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,107
    Seems like a good mod to me, eco car with eco mod would be great in stop start conditions, plus silence is bliss. No idea on any problems, was thinking it could cause acceleration issues but then thought soon as you hit the gas rpm changes same anyway, hmmmm.
    Jun 2006
    UK
    121
    Quote Originally Posted by 666markyboy View Post
    You need to go into the Engine controller and enter Adaptation 10, Group 02. The default value is 32768 which makes mine idle at 882RPM. I knocked mine done to 32700 which made it idle at 800RPM any lower than that and it felt a bit lumpy. You might want to switch on all your ancillaries i.e Full beam, indicators, fogs, air con & fan on highest setting, radio on basically anything that will load the alternator and make sure it doesn't stall or run lumpy. I put mine back to the default setting on the advice from above but there is surely no harm in experimenting?
  1. calling all 2.5 tdi owners
    By mikeya4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th May 2009, 20:11
  2. Calling all 3.2 DSG owners!
    By baz1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd January 2009, 23:01
  3. Replies: 36
    Last Post: 31st December 2008, 21:58
  4. Calling all Bilstein PSS/PSS9 Owner about Rear Spring
    By jomnhta in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2008, 15:55
  5. calling all 2.8 V6 owners
    By imported_christhick in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th September 2005, 12:49
