JMB RetrofitsEM Tuning
Results 1 to 9 of 9
    Oct 2010
    448
    How do you ground pin 1?
    I got clocks out and see where to gnd it but how do i wire from pin 1???????
    Oct 2010
    448
    I need something to put in there the plug to make a connection.
    Oct 2010
    448
    In the end I bought a wire from Audi. Part number. 000 979 009 E
    May 2012
    RETFORD, NOTTS
    1,753
    Scotch lock would suffice, two wires crimped on same connecting pin?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Oct 2009
    Hull
    1,442
    all I did was pull the plug apart its easy enough insert a bared bit of wire into pin 1 slide the cover over to keep the wire in place and bare the other end and put it on a bolt to ground it job done
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    Quote Originally Posted by @udi A3 View Post
    on every B6 i have done theres never been a wire in pin 1
    B7 has it
    Dec 2006
    barnsley
    1,016
    if you dont mind me asking but what is this actually for ?
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    bez101's Avatar
    Jul 2008
    8,492
    to stop the washer warning comeing on the dash
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    You can't scotch lock into a wire that does exist. this is a DIS retrofit and required a new ground wire to pin 1 of the 32 pin connector (grey one I'm guessing)
  1. How do you Take the circuit board off the Audi Key
    By powersurge in forum General Chat
    Last Post: 10th August 2012, 12:09
  2. how do you change the interior door lock pins?
    By jazzyc in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th June 2007, 23:31
  3. How could you get more power out of an Audi 5000S?
    By c_coffell64 in forum Classic Audi Forum
    Last Post: 22nd January 2004, 21:01
  4. How do you change those speakers??
    By RSAudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2003, 16:20
  5. How do you protect your....
    By jesters3 in forum Detailing
    Last Post: 14th May 2003, 14:11
