Chris NottAH Fabrications
Results 1 to 9 of 9
    Apr 2013
    stoke-on-trent
    73
    quattro exhaust on fwd
    Hi, as the title says. Will a quattro exhaust fit on a fwd a4, I know they are routed different because of the prop and reward drive shafts but is the floor pan the same? So it could hang as if its the car was a quattro?
    Rob
    Greeny233's Avatar
    Mar 2011
    Leuchars
    550
    Follow Greeny233 On Twitter
    As far as I am aware the Quattro floor pan and the FWD floor pan are the same. The exhaust should fit. The rear hangers are bolt on so you may need to get the offside rear silencer hanger and bolt it on.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    Apr 2013
    stoke-on-trent
    73
    Thanks I might take a punt on getting an s4 exhaust on my 190 avant. Just need to make an adapter pipe to connect to the downpipe.
    This must of been done but I've searched and can't find a proper answer.
    Rob
    boost-addict's Avatar
    Aug 2011
    977
    well i was told a fwd system wouldn't fit a quattro due to the route it takes and the way the exhaust is made to clear the diffs and propshaft.
    so i presume it wouldn't work the other way round?
    Apr 2013
    stoke-on-trent
    73
    From what little i be able to find quattro exhaust on fwd should fit but not fwd exhaust on a quattro.
    Does anyone know the size of the s4 exhaust tail pipe tips?
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,090
    Quote Originally Posted by rob0904 View Post
    Rob
    Whilst i think you could prosibly fit a Quattro exhaust i think you might have problems with one from an RS4 ... i'm guessing your thinking of the second hand one thats on eBay at the mo ???..... i'm not 100% sure but i'm guessing with the RS4 being a V8 that it's exhaust is 2 seperate pipes , one for each side of the V where as a normal Quattro one is a single pipe that gets spit into 2 tailpipes further down the system
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Apr 2013
    stoke-on-trent
    73
    Yeah an s4 system is just down the road from me. I was thinking of making some kind of Y piece to connect to the downpipe. The s4 system would have a greater Id, so I would to make a reducer too. If I can get the exhaust for pennies got to be worth a play or just cut the tips of to fill the valance better.
    Doesn't look like many have tried it and if they have they've never posted too much about it.
    Rob
    Mar 2008
    Oldham, Manchester
    1,090
    Well if you have the skills to manufacture a Y piece then maybe it's possible..... there's a cat back RS4 system on eBay at the mo for £75 which if it isn't a Typo seems very reasonable to me.... it's a tempting proposition
    Apr 2013
    stoke-on-trent
    73
    How much does the quattro exhaust sit under the car? Do you know the sizes of the 1.8t downpipe and the sizes of the 2 exhaust pipes that mate to the s4 downpipes.
    Rob
  1. A4 quattro exhaust
    By durham-dazzler in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th January 2011, 00:07
  2. 2002 3.0 Quattro Exhaust/Cat.....
    By fazanders in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd May 2010, 07:26
  3. 2,8 Quattro Exhaust
    By Nitro in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th August 2009, 16:38
  4. a3 quattro exhausts
    By mat20vt in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2008, 06:40
  5. 2.8 quattro Exhaust
    By qA4Blake in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2004, 05:05
