JMB RetrofitsBadger5
Results 1 to 13 of 13
    Oct 2010
    441
    DIS installed but 2 queries
    I have posted in retrofit but no-ones seems to reply there so I will post here to.
    I have managed to install the DIS wiper stalk and enable it with vcds. I have the washer warning as expected but I am testing the buttons and nothing is happening? Is this because the washer warning is preventing it?
    Secondly I know which pin 1 to ground on the back of the cluster with the blue plug however just read about it and I need repair wire? Can I not use normal wire I have laying about. Also where can I ground it? Any pics?
    Jun 2012
    Teesside
    448
    The patch wire is not a must, you can use a standard wire i believe, id double check the coding as ive had warning on for months since i fitted DIS (never got round to fitting ground wire) and always been able to use its functions with buttons,
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
    Oct 2010
    441
    The was 30100 and I tried 30200 which it didn't like then I did 30000. Should all clusters show various info.
    Oct 2010
    441
    Yeah I havent done coding under steering.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    • 0?xxx: Steering Wheel
      • 0 = Standard (without Multifunction)
      • 1 = 3-Spoke Steering Wheel (Sport Steering Wheel)
      • 2 = Multifunction Steering Wheel with Radio Control
      • 3 = Multifunction Steering Wheel with Radio/Telephone Control
      • 4 = Multifunction Steering Wheel with Radio/Telephone/Voice Control
      • 5 = Multifunction Steering Wheel with Radio/Voice Control
    • 0x?xx: Options
      • +1 = Tiptronic
    • 0xx?x: Board Computer & Cruise Control
      • 0 = Board Computer & Cruise Control not installed
      • 1 = Board Computer installed
      • 2 = Cruise Control installed
      • 4 = Board Computer & Cruise Control installed
    • 0xxx?: Rear Wiper (Chassis)
      • 1 = Rear Wiper not installed (Sedan/Cabriolet)
      • 2 = Rear Wiper installed (Avant)
    bez101's Avatar
    Jul 2008
    8,480
    03011
    if you have mfsw and saloon ?
    what steering wheel do you have and saloon or avant ?
    Oct 2010
    441
    Saloon 3 spoke
    bez101's Avatar
    Jul 2008
    8,480
    01011
    there u go
    Oct 2010
    441
    Hi bez. Thanks. under steering or instruments in vcds. What should it be under both?
    Oct 2010
    441
    Perfect. Was 01001 now 01011 under steering and under instruments was 30100 now 30000 or 31000 if you want 2 memories but I never use the life to date one. Thanks bez!!!
    bez101's Avatar
    Jul 2008
    8,480
    and you can use any wire for the washer warning
    as b6 dont usaly have anything in pin 1
    when you have the dash out you will see a 10mm you can ground to
    Oct 2010
    441
    Ok thanks again bez. Clocks look easy enough to remove.
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Memory 2 gives a more accurate mpg if you reset it each fill up
    A4 Avant 1.9 TDi Sport GmbH
  1. LED tail light installed but Air con fan stopped blowing
    By nicholastyc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd June 2012, 13:43
  2. Installing DIS, what a pain in the A*** to...
    By motosparkz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th October 2007, 17:45
  3. DIS Showing Door Open But Its Not
    By s3bow in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2007, 21:20
  4. IPOD in S3 but with DIS
    By dik in forum In-Car Entertainment
    Last Post: 30th June 2005, 20:54
  5. Upgraded to Concert II, lost HU in DIS/other query
    By hop2407 in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th October 2004, 16:15
