Chris NottMonster Motorsport
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    2.5 TDI timing - how often should this be checked / adjusted?
    My A4 Cab is on 122k, the timing belt is due at 140k.. I'm about to change the oil, should I check the diesel pump timing as well?
    2005 A4 Sport Cabriolet 2.5 TDI
    Previous Audis:
    1997 A6 Avant 2.5 TDI Quattro
    1994 80 Cabriolet 2.0
    1995 S6 2.2t 20v Quattro
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Can you check it FOC? If not I wouldn't bother as it will be upset when you have the timing belt done anyway, unless you've any reason to think it's out.
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    I'm changing the oil myself and I have VCDS so can do the check..
    I'm just not sure if it's necessary - I've heard that the timing drifts a bit as the belts stretch, but I don't know if it's worth worrying about and I'll only make it worse if I try tinkering with it.
    Previous Audis:
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
  1. How often should my pd be serviced ?
    By dale86 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th March 2013, 10:11
  2. How often should I service my S3?`
    By dragonstyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2009, 11:10
  3. How often should timing belt be replaced?
    By Kevan Young in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2009, 21:17
  4. a4 tdi PD Engine...how true is this??
    By vw754 in forum Diesel forum
    Last Post: 14th December 2006, 19:36
  5. How often do you see this!
    By Donald_MacIver in forum General Chat
    Last Post: 17th November 2006, 20:57
