Chris NottVolks Autos
Results 1 to 10 of 10
    Feb 2012
    20
    soft top light flashing 10 times
    hi, i need some help here. here it goes... soft top was down and when i wanted to put it back my mate sat on the soft top cover when it started to open... and after that it wont work properly. i tried to reset manually by opening and closing the top. but the light is still flashing 10 times. and when the top is up, when y try to bring it down cover goes up and then slowly goes down and top opens only 20%. when the top is down. the cover goes up top moves a little bit but it wont come out from the boot and the cover slowly goes down again. i dont think my mate could brake anything because all mechanism working fine. any ideas? could take a video and show you if anyone is willing to help. (sorry for my english)
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    if a manual open / close hasn't fixed it then you need to get the fault codes read via VCDS to understand where the fault is..
    2005 A4 Sport Cabriolet 2.5 TDI
    Previous Audis:
    1997 A6 Avant 2.5 TDI Quattro
    1994 80 Cabriolet 2.0
    1995 S6 2.2t 20v Quattro
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    Feb 2012
    20
    iv got the obdII cable and i tried to connect it with two different softwares EasyObdII and ScanTool but it wont connect. and i cnt get the error codes.
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,151
    You need VCDS to read the codes.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    as above if you have done the reset you really do need VCDS to see what the sensors are doing
    try the reset again tho sometimes takes more that 1 try
    on a side note i wouldnt let that so called mate near my car again
    Feb 2012
    20
    I did tried to reset more than once, but its still the same. Ill get it scanned n ill let u know the codes.
    bez101's Avatar
    Jul 2008
    8,480
    if no codes are stored even if they are
    look at measuring blocks for sensors
    Jan 2011
    684
    Need to scan it really. It's is very likely to be a micro switch or potentiometer that's throwing up a fault code. Google brings back plenty of options but without a scan you won't know for sure.
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    Feb 2012
    20
    if i scan and reset it would that fix the problem?
    Jan 2011
    684
    Worth a go I should say.
  1. Help needed !! Engine coil light flashing.
    By Leelacmn in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th February 2007, 15:19
  2. '95 80 Avant TDI running too cold/light flashing?...
    By mollyendo in forum Diesel forum
    Last Post: 26th April 2006, 16:00
  3. Gear lights flashing..help!!
    By imported_larry1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2005, 23:10
  4. alarm light flashing
    By stebed in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th March 2005, 22:05
  5. Anyone fancy a soft top A3?
    By TDI-line in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th February 2005, 18:35
