Q about electric windows
deano1978
different gear
near brighton
why is it that sometimes when i use the windows,that one touch opens it,others times i have to keep button pressed?
could be a broken wire in the door loom loosing contact every now and then which would mean you have to reset the one touch
not to sure,it happens on both sides.
its either one or another. (one push till open or keep finger on till open)
both at the same time?
not together,each side can be different,but it has happened thou.
its just a pain as its non consistant.
especailly opening the window a little
Possibly a dirty contact. Happened with mine recently that the drivers side would only go up when held. Sprayed some WD-40 on the switch and gave it a wiggle...sorted!
The switcb/button that controls the windows, on the door card
10
974
814
2K
749
T0m
677
